2080 Super Max-P? i9-10885H? Might as well light money on fire.
Discussion in 'Gaming (Software and Graphics Cards)' started by Nauzhror, Sep 16, 2020.
  1. Nauzhror
    Nauzhror Notebook Consultant
    The title is a bit click-baity, but it pretty much seems to be my takeaway from this comparison.
    Someone posted on reddit asking how decent this result on Unigine Heaven was:
    Someone else responded with their results:
    I then posted saying I'd run it, but that I expected to get smoked by the second result.
    Except, nope, didn't happen:
    That $3,000+ Omen 17 with a i9 and 2080 Super got matched by my $1,900 Clevo with a i7 and a 2070 Super:
  2. Tyranus07
    Tyranus07 Notebook Evangelist
    I think there is something wrong with that dudes setup. Maybe he was running on battery mode, or power saving profile. He is only 9% over the score of my 4 years old SINGLE GTX 1080 with a CPU with only 6 cores. A RTX 2080 Super should be at least 40% faster than my SINGLE GTX 1080
  3. DRevan
    DRevan Notebook Virtuoso
    If you are talking about the new HP Omen 17 with rtx 2080 Super and why is it performing lower then other 2080 Super cards....well the reason is easy: power throttling.
    HP installed a locked vBIOS with only 150W TDP.
    2080 Super was designed with 250W tdp.
    Other manufacturers like Clevo sets lower tdp at 200W which is still not enough to unleash the full potential, however still better than the 150W that HP choose.
    Because of this limit the gpu core clock does not boost as high as in other laptops so it performs worse.
  4. Nauzhror
    You have 2 1080's....
    A 2080 Super beating a SLI 1080 setup by 40% would be ridiculous IMO, I don't think even a desktop 2080 TI would outperform it by that margin.
    Different resolution, but as an example:
    Desktop 2080 TI (admittedly with a weaker CPU) only beats my laptop by 15.4% at 1440P.
  5. Nauzhror
    I can't see any laptop where it has over 200W, 250W in a desktop, sure, but in laptops it looks to be 150-200 across the board. Even at 150W though it seems weird for it to be outright matched by my 115W 2070 Super.
  6. Nauzhror
    Here's a 1080P comparison:
    Losing to a 2080 Super in a desktop by 25.54%.
    Beat your 1080 SLI setup by 36.29% most likely (I took the 8.56% I beat yours by and multiplied the results, ie. 1.2554 * 1.0856 = 1.3628, except I didn't round like that in the first calculation). A desktop 2080 TI probably does beat you by 40%, a 2080 Super in a desktop also comes close, but that's only with the full 250W, not with the limited 150-200W laptop versions get.
  7. Tyranus07
    But my score wasn't with SLI enabled. Single 1080, that's why I said 40% difference. single 1080 vs 2080 super
  8. JRE84
    JRE84 Notebook Deity
    just dude your 2070s will never beat a 2080s unless 2080s is power limited
  9. Tyranus07
    This one is the score of my SLI GTX 1080
    It seems it doesn't scale that well, only 53% jump in performance.
  10. yrekabakery
    yrekabakery Notebook Virtuoso
    CPU bottlenecked
    JRE84 likes this.
