2019 Razer Blade stealth performance
Discussion in 'Razer' started by Naeem Chandani, Dec 15, 2018.
  1. No0B
    No0B Notebook Consultant
    FYI, here's BIOS 1.02 and EC 1.01 for the Stealth 2019. Are these new by any chance? Didn't see them around.
  2. Joikansai
    Joikansai Notebook Deity
  3. No0B
    I was looking for new hidden updates for my Blade 15 and stumbled upon it. You'll see that the category that the file is in is erroneously "Razer Blade 15” (2018) Advanced". The file is not actually in there of course, because what file gets shown is dependent on the downloaditemid parameter in the URL. The itemids are incremental. Each time they upload a file it gets not a random number or string, but an increment of a number.
    Take the link for the BIOS for example:
    Code:
    http://drivers.razersupport.com//index.php?_m=downloads&_a=viewdownload&downloaditemid=3059&nav=0,350,765,766
    See how the itemid is 3059? Change that to 3060 and you have the EC file. The newest file is 3063 btw.
    The link that the download button leads you to is:
    Code:
    https://dl.razer.com/drivers/BladeStealth2019/RazerUpdater_v1.1.1.0_L1-BIOSv0102.exe
    Which would be the direct download link for the file. From that file we know that Razer names the 2019 Stealth "L1" (the Blade 15 2018 is C1). If they don't update the RazerUpdater, then you'd be able to eventually find BIOS 1.03 by changing the BIOS version in the link. It's how I found the Blade 15 1.07 BIOS for example.
    Joikansai likes this.
  4. Joikansai
    They seem take out stealth bios update due some issues that users reported I believe. Anyway it’s a great find. I’m good actually with 1.05, did you find anything new on 1.07 advanced btw.
  5. No0B
    Nope, nothing different for me compared to 1.06. But for @HAMSTERS it fixed something. Quoting from the thread.
  6. Joikansai
    Okay, I don’t have those issues on 1.05, battery fine, web cam fine, maybe I’ll just hanging with this for a bit longer till I feel uncomfortable.
  7. BartusCompater
    BartusCompater Notebook Enthusiast
    I believe they just released these to address the coil whine and battery discharge issues some people were experiencing with the 2019 Stealth.
    We'll see. I might be returning my Stealth because of these performance caps. There's no reason for me to not just stick with my 2017 Blade 14--it's only a little bit bigger, is much more powerful, and still has excellent battery life. I was hoping the Stealth would be able to outclass it in at least a couple of those categories.
  8. Richard Zheng
    Richard Zheng Notebook Evangelist
    Because some spoiled 5 year old will let the CPU take 60W because they are a "1337 G@M3R" and then complain online when it dies a year later
  9. chirrps
    chirrps Newbie
    N00b, do you also have a Stealth 13? 1.06 gives me intense camera flicker which destroys the usability of this laptop for me. I'm looking for a 1.07 bios for this or earlier to solve this problem. Can you help?
  10. No0B
    Nope.
    Unfortunately, not really. The only thing I can tell you is you could try to downgrade and see if the issue persists. I never had a new Blade Stealth in hand, but if the construction of the Blade 15 is anything to go by, then there's a possibility of the display/webcam cable having a bad connection due to being routed too tightly and opening and closing the lid. Open the machine and see if there's any heavy kinks (to a point of it breaking) in the webcam cable and if it's connected correctly.
    I didn't follow the Blade Stealth, since I don't have one, so now either they have deleted some previous BIOS and EC versions from their server (but the 1.02 download works just fine, so I doubt that), or I'm just not able to find 1.05. They have some inconsistent naming for the files and update the updater regularly, but any and all combinations that make sense don't seem to work. You can still give 1.02 a try.
