2019 Razer Blade stealth performance
Discussion in 'Razer' started by Naeem Chandani, Dec 15, 2018.
  1. Naeem Chandani
    Naeem Chandani Notebook Guru
    so I got my stealth acouple days ago and here’s a quick video I put together. Yes the fans are on MAX speed! 2019 Razer Blade Stealth 13 4K MX150 Unboxing and Gameplay
    Darkhan and Joikansai like this.
  2. Joikansai
    Joikansai Notebook Deity
    What brand of screen is that? You can check on devices manager, monitor and generic php monitor property by scrolling down to like devices instance path etc, usually it shows monitor/“display brands name/code“. And is that on right bottom display is backlight Bleeding?
    Vistar Shook likes this.
  3. Naeem Chandani
    No that is glare on the bottom right and the panel code is AUO202B
    Joikansai likes this.
  4. iMbaQ
    iMbaQ Notebook Evangelist
    What is noise and battery life like for productivity?
  5. Naeem Chandani
    Noise is minimal and battery life is 5-6hrs. I’m sure with tweaks and throttlestop it’s possible to achieve 7
  6. votehart
    votehart Notebook Guru
    Hi, Thank you for starting the thread.
    I am privacy hound and Synapse 3 is recording keystrokes all the time. I have tried to disable Synapse like did on the the previous version of Synapse but no success. If I go through some hoops with Services I can disable it. It will maintain a single color but if the laptop is turned off it will not retain the color and Synapse will not load. Little frustrating.
    Any ideas how to take Synapse offline?
    Other than this issue I have been very happy with the machine.
    Btw... Swapped the drive to the WD Blue 2TB M.2 SATA. Worked perfectly.
  7. Joikansai
    Never tried that but I heard previous Synapse could be offline-ed by changing appdata notepad like this guy did. How about trying that?
  8. votehart
    Thank you. I am going to try your suggestion. Hopefully S3 has a similar set of protocols. I am also see going to see if there is an option in the firewall to block S3 from sending data back to Razer.
  9. Darkhan
    Darkhan Notebook Deity
    New Bios and EC up on the website.
  10. Brad331
    Brad331 Notebook Enthusiast
    Razer hardcoded a power limit into the EC firmware. It throttles to 25W under CPU load and 15W under CPU+GPU load. That means, after a few seconds of full load, the CPU will be limited to 3.0GHz or less.
    After I posted this video, a YouTuber "Talons Tech Talk" commented that you could circumvent the power limits by making it believe it's using less power than actual. He says you could set in the BIOS:
    Code:
    Advanced/CPU VR Settings/Core IA VR settings/
    IMON Slope = 50 IMON
    Offset = 31999
    IMON Prefix = -
    I have already returned my Stealth at this point, so I can't confirm this. Any of you guys interested in testing this out? Maybe the EC listens to this, maybe not.
    I've already unlocked the advanced BIOS menus using AMIBCP, so you can just flash the ROM using AFUWIN.
    Joikansai and Arondel like this.
