2019 Razer Blade 17
Discussion in 'Razer' started by rickybambi, Apr 22, 2019.
  1. Joikansai
    Joikansai Notebook Deity
    This’s the same mobo Firestrike score from 3Dmark, I took the highest one, it may difference tweak like repasting, bios moding, Synapse setting etc.
    Lol
    vegetaeater likes this.
  2. rinneh
    rinneh Notebook Prophet
    That remark is kinda off, also not friendly. It takes tiem and effort for others to provide you with scores. You also could await benchmarks from review sites.
    seanwee likes this.
  3. YoungStarDC
    YoungStarDC Notebook Consultant
    I think he’s saying that he thinks there are a lot of rich people here, so not really an insult. Correct me if I’m wrong though lol :)
    vegetaeater and ubelai like this.
  4. Joikansai
    Lisa review for 2060 model.
  5. TomSifu
    TomSifu Newbie
  6. WhiteHelios
    WhiteHelios Newbie
    My blade pro 2080MQ power brick does get way hotter than any of my previous laptops. After extended sessions I can't lift hold it for more than a few seconds at a time.
    I wonder if this is actually a defect or do they usually run this hot? Since I don't have anything to measure the surface temperatures I can't give exact numbers but it does not feel normal for a brick to be this hot.
    Those with the new blade pro, does your power brick get unusually hot? Would be nice to hear from others on this.
  7. corteen
    corteen Notebook Consultant
    I have a new 17” and also a 15”...on both models the power brick gets very hot, similar to what you describe.
    I was concerned when I first got the 15” and had Razer send a replacement, the replacement was just the same, I then tried a colleagues power supply (he also has a 15”) and got the same results. Either every power supply is faulty or this is how they are designed to be.
  8. slimjim8201
    slimjim8201 Notebook Consultant
    My 2017 RBP brick gets very hot. Always has. Clearly, they all run like toasters.
  9. Papusan
    This is the price you'll have to pay for the nice and slim adapter design(as well probably cheap components). How long it will stay alive with this awful temps doesn't matter for the ODM. I'm not even sure they will cover a new psu if you went with extended warranty.
    Ashtrix likes this.
  10. YoungStarDC
    That’s pretty bad and maybe not even 100% safe :(
