2016 and Beyond: What are we missing in laptops/notebooks?
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by Mr. Fox, Dec 1, 2015.
  1. Doc Fox
    Doc Fox Notebook Geek
    Honestly, I have very modest wants;
    I want 2k+ USD laptops to be factory pasted with top end pastes with good application.
    I want laptop manufacturers to determine their own TDP that their chassis can dissipate and set the TDP on the chips accordingly. And also I dont want any unnecessary resistors on the pcb driving voltages up for no reason. Quite frankly nothing should be locked on my hardware... its mine, I should be able to melt it if I want... just void my warranty but dont make it difficult for me to use my own hardware...
    I want the body to be adequately rigid where I dont have to treat the laptop like an infant, preferably built with light metal panels.
    I want easily upgradable components, like the screen panel, storage, ram and easy access to the cmos battery. (Just make a little pop-open window at the bottom panel..)
    alexhawker and Aroc like this.
  2. TheUberMedic
    TheUberMedic Notebook Evangelist
    At least HP is listening for this one. Theyre adding liquid metal to that dual screen Omen 15
    Aroc likes this.
  3. TheUberMedic
    I just thought of 2 uses for folding screens for laptops.
    One is the Asus Zenbook Pro Duo approach but instead of two seperate displays, it's just one that folds.
    Another is one that wraps around the back of the display that folds outwards. If there was just 1 fold on the left and right side of the screen, we could have 32:9 screens for laptops BUT if then if the screen was double folded, we could have a 48:9 laptop! (same as triple screens)
    The second one is a bit out there but just an idea :p
  4. Support.3@XOTIC PC
    Support.3@XOTIC PC Company Representative
    Pretty sure ASUS is planning on that too.
  5. TheReciever
    TheReciever D! For Dragon!
    I prefer my t440p's and Rangers.
    Just like anything else, if you buy something for the branding you're burning your money regardless. Look at the individual model in question then move forward if your boxes have been checked.
    bennyg likes this.
  6. Moontei
    Moontei Notebook Enthusiast
    This x100 especially on thin and light gaming laptops that are all the rage now. Pretty much all reviews for such laptops show temps on the higher end and recommend you to undervolt it
    NuclearLizard likes this.
  7. NuclearLizard
    NuclearLizard Notebook Deity
    Yea, though in all due honesty you should probably undervolt any Intel CPU you get from the latter years.
    Just about everything I have seen runs like a furnace even my 6920hq in my GT 83 till I tuned it.
    Sent from my LM-Q710.FGN using Tapatalk
  8. Support.3@XOTIC PC
    Still want to see a magnetic charger connection in something higher end.
  9. Casowen
    Casowen Notebook Evangelist
    Laptop DIY builds? I would love that so much.
  10. TheUberMedic
    How about AMD desktop CPU laptops? Zen 2 Ryzen in a laptop would be great!
Similar Threads - 2016 Beyond missing
  1. avibs
    2
    653
