2016 and Beyond: What are we missing in laptops/notebooks?
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by Mr. Fox, Dec 1, 2015.
  1. inperfectdarkness
    inperfectdarkness Notebook Evangelist
    No point in having a 43" monitor, imho. I'm hoping that laser 4k projectors with 3000+ lumen will fall into the sub $2,000 range. That will eliminate all my problems.
  2. Georgel
    Georgel Notebook Virtuoso
    43" 4K - it is the same densityt as a 19" FHD display, just more surface.
    You can do a lot with it -> Code, anime, movies, work, everything is better at that size.
    mason2smart likes this.
  3. Dan@Dan
    Dan@Dan Notebook Geek
    This would be something i'd be eager to see:
    - 13 to 14", Blinding bright 4K Amoled Touchscreen
    - i7 8550U or i7 8650U
    - GTX 1060 Max-Q
    - Large WP-Trackpad
    -Fingerprint Scanner
    - TB3 4x for eGPU
    - SD Card Reader
    - RGB Keyboard
    - Fat battery
    - Convertible
    - Decent cooling with some headroom for gaming in the sahara
    - Upgradable RAM, WLan, M.2 (x2)
    This would be something i'd buy, if i had the money.
  4. Beemo
    Beemo BGA is totally TSK TSK!
    AMD GPU/CPU + Freesync that cost less than Nvidia counterparts.
  5. Support.2@XOTIC PC
    I keep hearing that roll-up displays are imminent, wonder how soon we could get something in the 40"-50" range that you can carry around in a tube. That would be awesome, you could have the machine in a box/pack, the screen rolled into a tube and then a folding frame attached to the side of the tube, so it turns into its own stand.
    Georgel likes this.
  6. inperfectdarkness
    Well hell, if Valerie came to fruition, we'd at least have screen real-estate to work with until roll-up displays or better projectors become the norm.
    For that matter, why not have a roll-up screen instead of a roll-up display? Build the projector into the laptop & combine it with a roll-up screen so you can have a 30+ display "on the go".
  7. Support.2@XOTIC PC
    Valerie looked like it was just begging, pleading even, to be accidentally broken. I'd sooner take a VR headset with me and use a virtual desktop for working, or suffer through a projector for presentation.
  8. inperfectdarkness
    Somehow, I don't think a built-in pico-projector is out of the question...but there's not enough "outside of the box" thinking to even build a prototype....yet
  9. Support.2@XOTIC PC
    Maybe Acer will try it. Whatever you think of the 21X, they were the ones who had the courage to actually release something as out there as a curved screen laptop. If anyone would build in a projector to a laptop, I'd look at them. Everyone else has been playing it much safer.
  10. Deks
    Deks Notebook Prophet
    Asus ROG Strix GL702ZC (Ryzen 1700 + RX 580 - desktop grade components).
    AMD APU - Ryzen 2500u + Vega (8?) iGP and Ryzen 2700u + Vega (10?) iGP.
    What I would like to see is a laptop with all AMD hardware that uses lower voltages and proper cooling execution so the machine can sustain maxed out CPU+GPU at the same time indefinitely and not go above 70 degrees C (in terms of higher end hardware).
    Plus a decent battery.
