2014 Razer Blade (14") & Linux
Discussion in 'Razer' started by mike.lwrnc, Apr 25, 2014.
  1. mike.lwrnc
    mike.lwrnc Notebook Enthusiast
    Hi folks. When my blade comes Monday I plan on trying my hand at dual-booting it with linux (I do scientific computing by day, and most of my tools are linux-based). I thought I'd start this thread in case anyone else tries the same in the meantime and has anything to report on the process. I'll certainly post my progress as I go.
  2. Zeelobby
    Zeelobby Notebook Evangelist
    I'm definitely interested. Do a lot of mri/ct processing using MATLAB, numpy, scipy, etc. Are you planning to partition the Hardrive or run from an external? I wonder how much access to the BIOS Razer allows.
    Sent from my Galaxy Nexus using Tapatalk
  3. mike.lwrnc
    I'm hoping to partition.
  4. aethelbert
    aethelbert Notebook Evangelist
    I'd be interested to see how this turns out. I currently own a 2013 Blade 14" and am disappointed to see that while Ubuntu 14.04 works pretty good, the touchpad is incapable of understanding multitouch gestures. Apparently the issue stems down to the implementation Razer has used to get the touchpad to work.
  5. Zeelobby
    Correct me if I'm wrong, but I'm pretty sure the Razer uses a Synaptics touch pad. If so then its really the lack of Linux driver support for those features which would cause them not to work. I haven't heard Razer had done anything crazy with their touchpads. That said you may be able to find a synaptics Linux driver for another device and force install it on the blade.
  6. mike.lwrnc
    Hm, I'm having trouble getting it to boot an ubuntu 14.04 live usb (created with the pendrivelinux.com Universal USB Installer). It shows up in the boot menu (as "UEFI: VerbatimSTORE N GO 1.00"), but when selected, the screen goes black briefly then off briefly then boots into windows. Nothing in the BIOS settings seem to be pertinent, but possibly I'm missing something?
  7. mike.lwrnc
    Fixed it. In the BIOS, in the "Boot" tab, I edited the "CSM parameters" section to have "launch CSM" enabled and made all other options "Legacy only" (not really sure if these are all necessary, but it works and has no detrimental effects otherwise).
    So far, everything seems to be working fine, including the touchpad tap-to-click and the touchscreen.
    jackie099 likes this.
  8. mike.lwrnc
    Doing some more thorough system checks, finding that:
    - nvidia card not being seen automatically (will try explicitly installing nvidia drivers next)
    - keys to increase/decrease screen illumination not working
    - keys to increase/decrease keyboard illumination not working
  9. mike.lwrnc
    Oops, mistakenly installed the 32-bit version of ubuntu; installing the 64-bit version now and will re-test everything...
  10. mike.lwrnc
    Next bump: while the i386 version of 14.04 installs fine, when I try to install the amd64 version I get a kernel panic on the first reboot after the installation. The error message is "Kernel panic - not syncing: No init found. Try passing init = option to kernel". Rebooting in advanced mode yields the following right before the kernel panic: "Starting init: /bin/sh exists but couldn't execute it (error -8)"
    Anyone have any ideas what's going awry here?
