2001 Camry doesn't read MP3 or WMA Help
Discussion in 'Motorized Vehicles' started by TomTom2007, Feb 20, 2009.
  1. batman5315
    batman5315 Notebook Evangelist
    i have the same car, it plays burned audio discs fine. I used TDKs and HPs most of the time. make sure you have closed the disc. dont leave the session open.
  2. TomTom2007
    TomTom2007 Notebook Deity
    Are you sure you have the same model as mine - Toyota 16814?
    There are about 3 different models of factory audio system, and I've got the cheapest and crappiest. Doesn't matter which disc or format I try, all the other car players and cd players play the music perfectly, but not with the Camry.
    Which software did you use by the way? Thanks.
  3. batman5315
    not sure if i have the same model, Ill check next chance i get
    i used nero to make the discs
  4. nfsnyc
    nfsnyc Notebook Consultant
    I agree, get a new audio system! I would go nuts if a CD player caused so much trouble!!!
  5. batman5315
    I have the same model, 16814
  6. Modly
    Modly Warranty Voider
    Just spend the money on something like this. They work fantastic, and offer iPod connectivity for later. I've got a slightly better model in my hearse, and another in my Caprice. It plays any CD I put in it, and it controls my iPod wonderfully.
  7. flipfire
    flipfire Moderately Boss
    Factory decks usually have a hard time reading burnt cd's.
    You can get a new head unit for under $100 w/ aux and ipod support. Installation will probably cost you abit more unless you DIY.
  8. Modly
    Crutchfield makes DIY auto audio stuff incredibly easy. They include instructions, adapter plates, and wiring adapters. I've bought 6 head units from them since 2000, and I highly recommend them.
Similar Threads - 2001 Camry doesn't
  1. Wyoming88!
    387
