1tb hard drive question
Discussion in 'Lenovo' started by hollyh, Mar 4, 2014.
  1. hollyh
    hollyh Notebook Geek
    are there any 3-4lb laptops that hold a 1tb hard drive currently on the market with lenovo? thanks!!
  2. ZaZ
    WD makes a 7mm 1TB drive that fits the the X2x0 notebooks. I have this drive in my X220 and it works quite well. The X230 and X240 can accommodate the drive too. I'd be more inclined toward the X230 for the mSATA SSD option, full voltage CPU and better trackpoint setup. The X240 has a larger touch pad if you roll that way and a FHD LCD, though I believe it is touch, which means glare.
    huntnyc likes this.
  3. hollyh
    thank you, that's great, x230 sounds best. this laptop isn't for me but i also have the x220 for myself and love it, i might want to upgrade the HD too.
  4. pipspeak
    pipspeak Notebook Deity
    The T440s has a standard 9mm drive bay as far as I know, so you could fit a nice, speedy 7K1000 drive in there
  5. soul347
    soul347 Notebook Evangelist
    Is there a reason you specified 3-4lb? Are you particularly looking for a laptop that is in the big/heavy side?
  6. hollyh
    good to know! i was looking at these as well
    i assume there aren't laptops less than 3lbs which hold 1tb hard drives
  7. ZaZ
    If you get the X220/X230 and use the four-cell battery, it's likely under three pounds depending on the particulars.
  8. dart22
    dart22 Notebook Consultant
    FYI: The X240 holds a 9.5mm drive
