1903 broke Clevo Control Center again
Discussion in 'Sager and Clevo' started by Boseph McGee, Jul 14, 2019.
  1. Boseph McGee
    Boseph McGee Notebook Enthusiast
    Hey friends! I've seen similar threads here. All of them are outdated and not applicable. Can anyone point me in the right direction? Thanks.
  2. notstaamp
    notstaamp Notebook Guru
    looking for the same thing :)
  3. Amnvex
    Amnvex Notebook Enthusiast
    I have the same problem. 1903 broke my CCC. Fan control doesn't work (different profiles), FN + LED lights on/off doesn't work, and FN+Touch pad key doesn't work... all of this worked prior to 1903! If someone has any solution/idea, do share!
  4. jc_denton
    jc_denton P870TM1-SKYLINE
    1903 seems to be breaking a lot of drivers. Perhaps uninstalling and reinstalling CCC might solve it, if not try a different version until you find the one not completely borked by the update.
  5. 4W4K3
    4W4K3 Notebook Evangelist
    What version are you on and what is not working? These details are crucial to help find a solution. Have you tried a basic re-install of CCC after the update?
    I'm on Windows 10 Pro 64-bit 1903 Update with Clevo CC 3.0 V1.24 and everything works fine. Obviously there is some discrepancy here.
  6. Amnvex
    For me, I tried CCC 3.0 v. 1.30, 1.24, and 1.14. Switching profiles, for example for the fans, just makes the profile always go back to Quiet Mode after clicking the back button and back into the profile for them. No ACPI errors or anything from this. And the LED control works, but not with the FN + * (on numpad) to turn on and off. They also don't react to FN + - and FN + + for brightness control.
    And yeah, tried reinstalling and installing and none of it is working. Even more interesting: After having upgraded, I get hkmoufltr.sys crashes on Chrome constantly. CCC has updated this file, so it's not the original. I think the record is 6 BSODs in 8 hours. Something really weird is happening post 1903.
  7. Amnvex
    Guys, I managed to fix it all :eek:
    First, I uninstalled CCC and ran these in powershell:
    • DISM /Online /Cleanup-Image /RestoreHealth
    • Get-AppXPackage -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
    After this, I restarted and reinstalled CCC.
    Everything works again! Try it. See if it helps?
    crapp0 likes this.
  8. Notebookbackbreaker
    Notebookbackbreaker Notebook Geek
    The tip above should work for fixing windows image integrity and, if CCC has drivers which poll windows dll's and somehow have lost permissions during the migration, a reinstall of CCC post the restore process should fix it.
    On a funny note: The time has come for windows 10 users to try and run programs in compatibility mode for an earlier service pack/update version. Oh boy microsoft... oh boy.
    Papusan and Amnvex like this.
  9. crapp0
    crapp0 Notebook Enthusiast
    Hi,
    I just tried what you posted, and my control center still wont launch for some odd reason.
    When it used the 2nd command, i get a few red colored messages which seem to indicate some items were not cleared?
    Would that affect the ability of control center to launch successfully?
  10. Amnvex
    Did you uninstall the control center before doing that? I uninstalled all related things to CCC before doing those methods.
