17 R4 1080 7820HK - Audio Quality + Settings
Discussion in '2015+ Alienware 13 / 15 / 17' started by prastis, Jan 19, 2018.
  1. prastis
    prastis Notebook Consultant
    Guys just received my refurbished laptop and everything looks great. Temps look good but there is the core differential problem but max temp after occt test at stock settings reached 75 high with 65 on the other cores. anyway...
    The sound although it sounds good, it sounds a bit low in terms of volume. even on highest audio, the sound still isn't that loud compared to my dell xps l702x. any feedback or suggestions? could it be malfunctioning or if it was malfunctioning it would be disoriented or bass related?
    thank you.
    George
  2. Vasudev
    Have you tried changing Audio quality from 16 bit to 24 bit 192kHz Studio quality?
    Right click on Sound icon, select Playback devices > Advanced.
    Pete Light likes this.
  3. prastis
    thank you, I think it helped :)
    Vasudev likes this.
  4. l4k3rkb
    l4k3rkb Notebook Consultant
    Have you checked out the Alienware Sound Center? I use the "Movie" preset for movies and the "Alienware" preset for games and music, both with the bass turned all the way up and volume leveling off. My custom EQ settings make the laptop sound quite amazing; it surpasses the XPS in my opinion with these settings.[​IMG]
    MogRules and Vasudev like this.
  5. MogRules
    MogRules Notebook Deity
    Thanks for these :) these settings sound pretty good!
    Vasudev likes this.
