17" Lightweight notebook for general use
Discussion in 'What Notebook Should I Buy?' started by Nintendam, Feb 23, 2016.
  1. Nintendam
    Nintendam Notebook Consultant
    Hi All, looking for a laptop for my family member
    General Questions
    1) What is your budget?
    $1000 EDIT: $500 (oof)
    a. Netbook; 10" screen or less
    b. Ultraportable; 11" - 12" screen
    c. Thin and Light; 13" - 14" screen
    d. Mainstream; 15" - 16" screen OR
    e. Desktop Replacement; 17"+ screen
    Anywhere
    Open
    Perhaps
    General Use/ Microsoft Excel/
    Portability is a plus, lighter, thinner
    Probably not, but discrete gpu is a plus
    More the better
    meh
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    win7-10
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    • Maximum Resolutions: WSXGA+, WUXGA, FHD, 1080p
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Either
    Build Quality and Design
    yes
    ASAP
    3-4 years ish, pretty much as long as a $1000 can last
    Notebook Components
    SSD
    yes, dvd minimum, blu ray a plus
    I've recommended the new Dell XPS 15, as the non touch is 999.00. As for 17" I'm unsure of options right now. I don't believe they want to go sager/clevo route unless one is thin/light enough
    so..... I've found this: good deal?
    I hear the display is not that great-
    http://www.newegg.com/Product/Product.aspx?Item=N82E16834315131
    Thanks!!!
  2. Kent T
    Kent T Notebook Virtuoso
    The above won't happen. 17" and 3-4 years lifespan and you're looking at 5 pounds to lug. And it's going to be a bit thicker to handle a discrete GPU and keep it cool.
