15" MSI GE63 2080 non-maxQ vs other maxQs (Blade 15, GX531GX, GS65...)
Discussion in 'What Notebook Should I Buy?' started by Bill'O, Feb 10, 2019.
  1. Bill'O
    Bill'O Notebook Enthusiast
    Here is comes again,
    Trying to decide whether I go for a maxQ or not 2080 since I feel the size of a 15 like the
    GE does not really bother me.
    trying to find reviews of the GE63 with real 2080 card.
    I consider LM repasting as well.
    What about the different maxQ watts models ?
    General Questions
    1) What is your budget?
    Under $3200
    one that fits in my dakine classic backpack
    3) Which country will you buying this notebook?
    FR/EU
    I want a proper finish product, clevo would go last lets say
    No.
    Gaming - Dev - PUBG BF5 and so on
    I will be taking it different places, once a week
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?)
    Yes
    Pretty much irrelevant as I'll be using the brick 99% of the time.
    no
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    Windows/Unix
    Screen Specifics
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    1920 x 1080
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (See further below for explanations.)
    No
    Build Quality and Design
    Better than Clevo, especially in terms of screen.
    Notebook Components
    15) How much hard drive space do you need?
    512GB
    Timing, Warranty and Longevity
    16) When are you buying this laptop?
    2morrow, need it for work
    17) How long do you expect to use this laptop?
    3 years
  2. Vistar Shook
    Vistar Shook Notebook Deity
    The 2080 is a lot better than the 2080MQ.
  3. Le Quan
    Le Quan Notebook Consultant
    If you dont mind the extra weight and weaker battery life (about 3hrs on baterry), go for the GE with RTX2080. Much better cooling and performance for both CPU and GPU. Also, the GE75 has almost similar dimension and weight but has a bigger screen. Remember to upgrade to dual channel memory since most versions of GE63/75 comes with single ram. Go for LM if possible.
    397 x 268.5 x 27.5 GE75 (2.6Kg)
    383 x 260 x 29.5 GE63 (2.6Kg)
    Other laptops with Max-Q GPU are around 2Kg and much thinner.
    Bill'O likes this.
  4. Bill'O
  5. Le Quan
    Almost all the thin and light gaming laptops have the option for RTX 2080 maxQ (Razer Blade, Aero 15, MSI GS65, New Clevo 15", Alienware m15, Acer Triton 500, Asus Zephyrus S 15 and 17", etc.). You can check out owner's threads for these laptops for performance of the MaxQ version.
    Bill'O likes this.
  6. Bill'O
    indeed but I'd like to know how they compare between each other say the Asus Zephyrus S 15 2080mq vs Razer blade 2080mq, maybe too soon to know atm though...
  7. Vistar Shook
    Bill'O likes this.
