14inch (or small 15") Laptop with specific requirements
Discussion in 'What Notebook Should I Buy?' started by swooph, Nov 7, 2017.
  1. swooph
    swooph Notebook Geek
    Hi guys, any help with this one? High spec machine needed.
    1) What is your budget?
    £2000
    14" ideal but will consider a slim 15"
    UK
    Don't mind
    Yes
    Everything except gaming. Sound and Video editing. Should be a very high spec machine.
    Both
    NO
    More the merrier
    Don't ming
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    Win 10
    Screen Specifics
    12)
    I love big resolution but wont tolerate a glossy screen. so if it's glossy i prefer to go down to a 1080 and get a non-reflective.
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    Build Quality and Design
    Yes
    Now
    2-3 years minimum
    Notebook Components
    I need a big SSD but am happy to install my own.
    No
    OTHER STUFF
    MUSTS
    I need traditional USB 3s (at least 2), preferable at least one on either side.
    and here's the kicker
    in an ideal world this laptop will have DEDICATED pg up and down keys (no pressing ctrl / shift)
    Backlit keys
    Up-gradable SSD / RAM would be lovely but not a must, if the machine is of high enough spec.
    I think that's it. Any help, as ever, greatly appreciated.
  2. ZaZ
    The ThinkPad T470p might be worth a look.
    Starlight5 likes this.
  3. swooph
    Could be a good shout that... thank you
  4. laserbullet
    laserbullet Notebook Evangelist
    JRE84 likes this.
  5. swooph
  6. swooph
    no votes for the Elitebook 1040?
  7. rlk
    rlk Notebook Evangelist
    Dell Precision 7510/7520? Lenovo P50/P51/P51s?
    These aren't particularly small examples of 15" (the P51s is considerably smaller), but if you want lots of compute and graphics horsepower, the chassis has to be able to dissipate quite a bit of heat. That's also going to make battery life miserable. The lighter laptops tend to use U-series chips with 2 cores, which consume a lot less power, so less throughput than the higher end ones (but not necessarily less per core, if you're single threaded).
    I have a Lenovo P70 (I had been a Dell man all along, from the Inspiron 8000 through the M6500), but I like the ability to add a second 2.5" drive to the P70 that can't be done with the Dells. None of the 15" machines offer that (well, there's a Clevo model or two that does). I do a lot of image editing, and the programs that support OpenCL really crank compared with my M6500 (it takes about 4 seconds to do a series of processing steps that took 25 seconds with the old laptop -- with programs that don't support OpenCL, it's more like 8-9 seconds). This is running Linux.
    I'm not sure about the P51s, but the others all offer choice of FHD or UHD screen. The UHD is really a lot crisper, particularly if you like small fonts. Both the Lenovo and the Dell offer good color gamut with matte screens with the UHD screens; the FHD ones are another matter. If you insist on working in bright sunlight backlit you'll have glare, but you would with anything.
    HP also offers the Z-series; I don't know as much about that. Gigabyte does too, but theirs only takes 2 DIMMs and it's apparently very hard to find replacement parts if you need to.
    Finally, look at the respective refurb stores online; they offer some good configurations.
  8. JRE84
    JRE84 Notebook Virtuoso
    aero 15x if you can afford
