1440p-4k budget monitor for gaming and Light Room?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by NYCtech, Apr 1, 2018.
  1. NYCtech
    NYCtech Notebook Consultant
    I plan to hook up an old notebook to it occasionally for web browsing and doing my light room work.
    But I also intend to hook up a Xbox one X to it.
    And possibly a smartphone.
    So I need at least 100% sRGB, reasonable response time for gaming.
    Size isnt a huge concern either way.
    Not sure if I put this in the best forum as there isnt a dedicated monitor forum.
  2. KY_BULLET
    KY_BULLET Notebook Evangelist
  3. tilleroftheearth
    An 'old notebook' for gaming and LR work with an up to 4K monitor isn't the best match for a good experience.
    What are your notebook's spec's?
  4. Support.2@XOTIC PC
    BenQ GW2765HT. I have a similar 2K from them (that I think has been superseded with a newer model) and it looks great. The 4K should look even better.
