14” monitor, 1920x1080, 100% scaling with Windows 10: text too small or not?
Discussion in 'Windows OS and Software' started by hendra, Jun 7, 2019.
  1. hendra
    hendra Notebook Virtuoso
    How does it look like if you have a 14” laptop with native resolution of 1920x1080 and set the display at 100% scaling with Windows 10?
    Would every text still look too small? Do you need to bump it up to 150% scaling?
  2. Jarhead
    Jarhead 恋の♡アカサタナ
    That’s a personal question. Personally, I have my smaller laptops (12.5”) set to 1080 100% and can read everything just fine at normal screen-to-face distances.
  3. 6730b
    6730b Notebook Evangelist
    Have settled for 125% in W, & 110% in browser (FF), looks fine for my 'somewhat less young' sight, and allows some distance to display.
  4. StormJumper
    StormJumper Notebook Virtuoso
    What you should do with Scaling is to match the LCD recommend resolution that will insure proper readable text. Scaling doesn't give you better text to read. Scaling will make the text bigger but become out of focus.
  5. Che0063
    Che0063 Notebook Consultant
    13.3" user here. 125% @ 1080p is fine. Though I have it set to 150% because at home I dock my tablet 1m away from my face. When at 100%, I do need to be 60cm away to see everything, but 60cm is about normal usage distance. 14" 100% 1080p should be fine, just a tad smaller than the 100% 15.6 1080p experience I was used to having.
    @StormJumper
    I think OP meant this:
    Everything is rendered at native res but font sizes just become bigger.
  6. Spartan
    Spartan Notebook Nobel Laureate
    on my 17 inch screen 100% scaling is just OK with the 1920x1080 resolution but I feel more comfortable if it's at 125% scaling but have forced myself to get used to it since I don't want to deal with the blurriness of DPI scaling in apps that don't support scaling properly or have misaligned text or buttons so.... on a 15.6 screen IMHO... no way.......on a 14 inch screen......I wouldn't do it even if you paid me unless you plan on damaging your vision.
  7. rlk
    rlk Notebook Evangelist
    It's purely a personal matter, and it can change over time as one's eyesight changes.
    I don't run Windows personally; I'm using Linux on a 17" UHD screen with fonts that most people around here seem to consider too small on a 21" FHD screen. My left eye is currently nearsighted to the degree that at a comfortable viewing distance it works. I boot Windows once in a while just to update it; I don't recall whether I have 150% or 175% scaling set up or what font sizes are set (probably small ones to the extent it's controllable in that environment).
    My primary font (emacs and xterm) is 9x15 pixel. On my old laptop with a 1920x1200 screen (before those fool 16:9 screens took over) I use 6x10. So the characters are somewhat smaller in linear dimension but the greater number of pixels improves readability.
