120Hz 3D Screen upgrade for Alienware 17 R1
Discussion in 'Alienware 17 and M17x' started by MogRules, Aug 3, 2014.
  1. Pron1o
    Pron1o Notebook Enthusiast
    hello guys, can you tell me something about LTN173HT02-X01, it works too with ranger?
  2. yuval_
    yuval_ Newbie
  3. yuval_
    yuval_ Newbie
    The 4K IPS panel has been successfully replaced. The 120Hz 40-pin and 4K 40-pin connector definitions are the same. If the hardware exactly matches, do the BIOS need to be modified?
  4. Werss
    Werss Newbie
    Pron1o
    LTN173HT02 - X01 It's not working C01=X01
  5. Werss
    Werss Newbie
    today I bought N173HHE-G32 works fine, BIOS native gpu780m, mountings needs some work. this is a tn panel 120hz 5ms, ips+120hz panel doesn't exist.
  6. yuval_
    yuval_ Newbie
    Can u talk somethings about the model of this video cable? Can u share purchase sources and pictures?Give me your email address, I want to communicate with you
  7. Werss
    Werss Newbie
    Video cable n392w DC02C004000, there is a problem with the installation of N173HHE-G32. electronic Board does not allow to close the decor panel. there is only one way to install the panel. the electronic Board must be recessed under loops. I'm working on it, and I hope I can do it.
