1080 vs 1070 for longevity?
Discussion in 'Gaming (Software and Graphics Cards)' started by dakome, Jun 6, 2018.
  1. dakome
    dakome Notebook Enthusiast
    I'm looking at buying a laptop from HIDevolution, and can't decide between spending the extra $400 for the 1080 instead of the 1070 card.
    The main thing I'm concerned about isn't so much power right now - but more in terms of longevity for the future... is the gap between the cards significant enough to make one more usable in say 3-5 years than the other, with the titles that'll be out then?
  2. saturnotaku
    It depends on what resolution you'll be using. For 1080p, a GTX 1070 will be more than adequate for years. For 1440p or higher, a GTX 1080 will be a wiser investment in the long term.
    Vasudev likes this.
  3. Vasudev
    Both are really old nowadays and if you can wait for new gen GPU from nvidia it'll be worth it!
  4. dakome
    Oh no... that's depressing! Gotta get this laptop in the next 2 weeks :\
    Vasudev likes this.
  5. Vasudev
    Oh well! Get the GTX 1080 with Vapor chamber so that you can Overclock in future. Are getting a Clevo or MSI barebone?
  6. dakome
    Yeah looking at Clevo custom built via HIDevolution. Also not sure about 15" or 17"... intuitively I'd think if I'm almost always using it plugged into a monitor, 15" is more power for the money but they seem to be around the same price...
    Vasudev likes this.
  7. Vasudev
    Get the 17" for cooling power since you're connected to AC all the time. Invest in some good keyboard and mouse combo like steelseries, logitech etc. And a stand will help too. @Donald@HIDevolution can help you with that.
  8. dakome
    Thanks - didn't realize the larger one is better cooling, good tip!
    Got the keyboard/mouse sorted from my current setup :)
    Though this is for work... for play I may need a traditional mouse ;) (haven't been gaming in a really long time... looking forward to getting back into it!)
    Vasudev likes this.
  9. Vasudev
    Which is that mouse? I've never seen it! Looks like Men in Black Alien Tech.
  10. dakome
    haha - yeah it's the ELECOM M-HT1URBK Wired
    Vasudev likes this.
