1080 max q vs 1070 for VR game development
Discussion in 'Gaming (Software and Graphics Cards)' started by bigmojo, Oct 26, 2017.
  1. bigmojo
    bigmojo Newbie
    Hello everyone, I just have a question about your thoughts on which is the better choice if I wanted to do VR game development work on a laptop.
    I've seen extensive benchmarks and comparisons, some showing that both are very similar while others show some larger performance gaps, but those have primarily been synthetic and gaming benchmarks.
    When it comes to game development will the comparison show different results? Will one or the other prove to be better suited for the job?
  2. Vistar Shook
    Vistar Shook Notebook Deity
    Because of the big price difference, the 1070 is a better value, since it will perform similar to the 1080MQ when overclocked.
  3. bigmojo
    bigmojo Newbie
    Are there any advantages to having gddr5x vs gddr5 for purposes of game development?
  4. Vistar Shook
    I don´t think there will be any noticeable difference.....but to get the best performance you should opt for a full 1080, not the MQ....certainly not worth the same price for the performance decrease.
  5. bigmojo
    bigmojo Newbie
    If only 1080 laptops didn't weigh a ton...I do plan on taking my laptop with me to and from school.
  6. hfm
    hfm Notebook Prophet
    EVOC 16L-G-1080 / Eurocom Tornado F5 are only 6.5lb. that's about as good as it gets for a 1080 unless you go maxQ
    EDIT: Honestly, for school purposes, I'd sacrifice some power and get something thin-and-light with gobs of battery life. You can use iGPU on the go (I wouldn't settle for anything less than 7hrs so you don't have to cart a power adapter around) and have a 1060 dGPU so you can plug in and game. That's just me though. I wouldn't bring this EVOC to school/work with me it needs to sit next to an outlet at all times basically.
    Vistar Shook likes this.
  7. bigmojo
    bigmojo Newbie
    Thanks for our advice. I'll take a look into the choices out there. I recently had a chance to play around with the asus zephyrus at a computer shop and it really feels amazing to see and feel IRL lol
  8. Charles P. Jefferies
    The GTX 1080 Max-Q performs very similarly to a GTX 1070 (non-Max-Q) as noted ...really not worth the premium. The GTX 1080 Max-Q is perhaps 10 percent faster on average.
    The GTX 1070 Max-Q, on the other hand, performs within about 10 percent of a GTX 1070 (non-Max-Q). So maybe look at something like the Gigabyte Aero 15X. Very portable machine with good battery life.
    The Asus Zephyrus has awful battery life, BTW.
    Charles
  9. wyvernV2
    wyvernV2 Notebook Evangelist
    1070 stock vs 1080mq, the 1080 will perform a littlebit more.
    However if yu buy a laptop that can hold oced 1070, go for it, it'll definitely wreck 1080mq
  10. nixliu
    nixliu Notebook Consultant
    1080ti will working better. but$$$$$$$$$$
