** 1070 laptop: GT73VR, GT62VR, GT72VR reboot/crash problem **
Discussion in 'MSI' started by Hugodra, May 17, 2017.
  1. Falkentyne
    Falkentyne Notebook Prophet
    Did you *turn off* the laptop after flashing the 8A vbios?
    Flashing the 8A Vbios and rebooting does absolutely nothing. The laptop MUST be shut off completely and unplugged first, then turned on again.
  2. GoesTo11
    GoesTo11 Notebook Enthusiast
    I did shut it down but I didn't unplug it. Afterburner is reporting 1645MHz so it looks like it is working.
  3. Falkentyne
    The 8A vbios simply caps the GPU voltage at 0.881v (usually 0.875v), not at any particular clockspeed.
    The "faulty" 1070's would crash when the voltage reached 1.013v.
  4. GoesTo11
    It's running at 0.894 volts. I shutdown the computer and uplugged it and it is still running at 0.894 volts. Does that mean that the 8A bios didn't get installed correctly?
  5. Falkentyne
    0.894v is a roundoff error. Should be 0.881 precisely. But it's working
    Your crashes are for a different reason, then.
  6. GoesTo11
    It solved crashes during Dirt Rally benchmark mode but it still crashes during actual game play.
  7. Falkentyne
    This is all I can suggest and I"m sorry if it doesn't help you, as I am not a windows or a videocard troubleshooter tech.
    Do a full factory reset of windows.
    A clean installation.
    It's best if you have a spare hard drive or SSD sitting around or even a platter drive with a USB to SATA Adapter or anything.
    Do a clean fresh new installation of windows. I suggest the windows build BEFORE 1803. The spring 2018 update was pure garbage.
    Install Nvidia driver 391.35 or 391.48. Install MSI SCM only. DO NOT INSTALL DRAGON CENTER. PERIOD.
    Install the realtek drivers and touchpad.
    Then test your games.
    Report back if it crashes like this.
    If it does, RMA the laptop.
  8. GoesTo11
    I think that I figured it out. I had two issues that were interacting with each other. I was getting EMI issues from a new Direct Drive wheel. Moving the laptop away from the wheel didn't solve the problem because of the issue with the 1070. Just using the new vbios didn't work because of the EMI issues. Doing both seams to have worked. Thanks for the help.
  9. Vamsi Krishna Saladi
    Vamsi Krishna Saladi Notebook Enthusiast
    Hey Hugodra,
    I am facing this issue and i couldnt recognize the issue till now as my windows somehow was not logging the issue. i was referred to you by some friend. My laptop is GT 62 VR having this issue
    My laptop came with OOO vbios 86.04.31.00.0d
    And i recently updated to BIOS: E16L2IMS.117 hoping this version may solve my issue.
    Getting errors like:
    DirectX : 0x887A0007 DXGI_ERROR_DEVICE_RESET
    Windows: Hardware error - live kernal event ; code 141
    As you said bios verison 8A can solve this issue. can you provide me download link ?
    or any other assistance please, i really need your help..
  10. Vamsi Krishna Saladi
    Hi Falkentyne,
    can i use this same bios 8A which you uploaded for my GT 62VR i also have issues with crashing games with core clock touching 1850+ Mhz with out overclocking ..
