** 1070 laptop: "bd prochot" causing cpu throttling to 800MHz and stuttering **
Discussion in 'MSI' started by streetunder, Feb 13, 2018.
  1. Pedro69
    Pedro69 Notebook Evangelist
    And what cpu you recommend? 8700k or 7700k...i asked about noise because i checked many issues about that even in models with 7700 hq.
  2. Papusan
    8700K (50% more cores).
    Vasudev and Falkentyne like this.
  3. senso
    senso Notebook Evangelist
    And if you dont get the Clevo from one of the few stores that have partnership with Prema it will have as ****ty or even worse firmware than MSI....
    Only Clevo Center in Portugal has partnership and its a scummy store, there is Obsidian PC doing their mods and so far seems to be working out ok.
    Then, there is not much else in Europe..
  4. Pedro69
    Senso, you are from Portugal? Yeah, i know clevo center but the prices not are the best...im thinking in a buy with 17 inch, 120hz without discs,ram and cpu...i can buy this things more cheaper than in clevo center.
    If i need a Bios, @Prema can sell one to me?
  5. Pedro69
  6. heliada
    heliada Notebook Evangelist
    @Pedro69 have you tested it yet? Does it fix the bd prochot?
  7. Pedro69
    Will test right now.
  8. Falkentyne
    Falkentyne Notebook Prophet
    It can't fix BD prochot. This is controlled by the EC. Bios has no control. EC can override anything the Bios can set.
    Order of priority is 1) PECI, 2) MMIO, 3) MSR.
    Referring to power limits and throttling.
    PECI is controlled by the EC
    MMIO is memory mapped IO. Has a higher priority than MSR's
    MSR are CPU registers. Bios has access to those.
    Vistar Shook, heliada and Pedro69 like this.
  9. Pedro69
    Any luck with that thing of "MSIHIDDENFUN"?
  10. heliada
    @Falkentyne, well I don't know how EC firmware detects hardware (you talked about that a lot), but I was wondering if bios could not influence it somehow. But then again, it was just me hoping for a miracle.
  11. Pedro69
    All the same, even with the new Bios, Bd Prochot still appears at very low temps...55ºC CPUe 65º GPU.
    There is a issue that i forgot to mention and not happen only with this new Bios, if i not undervolt the 7700HQ, when i got the BD Prochot first the frequency goes to 2.7GHz and only in rare cases i get 800Mhz...if i undervolt with 140mv(core and cache), never see the value 2.7GHz...with undervolt when i got the BD Prochot go always to 800MHz, strange :tears::tears::tears:
