1060 upgrade help
Discussion in 'Sager and Clevo' started by Anakin_loRd, Jul 26, 2017.
  1. Anakin_loRd
    Anakin_loRd Notebook Enthusiast
    Hello guys, bought a 1060 mxm for my laptop and after installing the card i am getting flickers with wavy screen as shown in the video please help, is the card faulty?
  2. Anakin_loRd
    I have a clevo p775dm1g
  3. thegh0sts
    thegh0sts Notebook Nobel Laureate
    the card is not faulty. it means the vbios that has been flashed onto the 1060 is a gsync vbios and it's not compatible with your laptop.
    don't fret, you just need to find another 1060 vbios and flash it.
    I had a similar issue when installing the 1070 into my P870DM-G where it persisted from the BIOS screen to Windows and I am assuming it's doing the same here. flashing the vbios with another vbios should fix it. try any of the MSI labeled files here:
    <link removed>
    Unfortunately you only have 2 options.
    EDIT: don't expect gsync to work because it won't. the motherboard does not contain the GPU ID to make it work anyway.
    EDIT 2: Use the official MSI 1060 vbios in the post below.
    Anakin_loRd likes this.
  4. thegh0sts
    Anyway, try and check what vbios version you have and flash the latest version. hopefully it should go away. if you're successful then we can add this to the list of upgrades that can be done safely.
    Scratch the techpowerup link, how about trying the latest version from MSI:
    https://us.msi.com/Laptop/support/GT62VR-Dominator-6th-Gen-GTX-1060.html#down-firmware
    try the non-gsync version since gsync doesn't work. they should come with nvflash so it should be easy to do.
    So yeah, try doing this first before freaking out. Let us know if you need help with using nvflash because there's no point in freaking out if the fix is so easy.
    Falkentyne likes this.
  5. Anakin_loRd
  6. Anakin_loRd
    getting this error:
    NVIDIA Firmware Update Utility (Version 5.319.0)
    Simplified Version For OEM Only
    Checking for matches between display adapter(s) and image(s)...
    Adapter: GeForce GTX 1060 (10DE,1C60,1558,7702) H:--:NRM S:00,B:01,D:00,F:00
    WARNING: None of the firmware image compatible PCI Device ID's
    match the PCI Device ID of the adapter.
    Adapter PCI Device ID: 1C60
    Firmware image PCI Device ID: 1C20
    WARNING: Firmware image PCI Subsystem ID (1462.11FF)
    does not match adapter PCI Subsystem ID (1558.7702).
    NOTE: Exception caught.
    Nothing changed!
    ERROR: GPU mismatch
  7. thegh0sts
    try the other version.
    I went back to find which vbios i used to flash my 1070 with and it was indeed a gsync vbios and it worked fine.
  8. thegh0sts
    After talking with @Anakin_loRd I can confirm this issue is now resolved.
    Enjoy your upgrade!
    Falkentyne and sicily428 like this.
  9. SMGJohn
    SMGJohn Notebook Evangelist
    LOL what he do? Just flash multiple vbios?
  10. thegh0sts
    You have to flash a compatible vbios for the card. After that it's smooth sailing.
    Sent from my SM-T560NU using Tapatalk
