ِNeed Help Upgrading My Alienware M15X
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Duke Nukem Rayne, Dec 29, 2020.
  1. Duke Nukem Rayne
    Duke Nukem Rayne Newbie
    Hello Everyone I'm Kind of of Noob here in upgrading Laptops GPU And CPU
    i Found MXM GTX 980M 8GB And i want to install it into my laptop
    i heard that i might need a new charger + some tweaks in NVidia drivers !!!
    but do I also need a bios update since my laptop bios is old A08 ?
    my laptop specs are I5 540m dual core + gtx 460m + 8gb Ram + 256 SSD
    PS: i have both a 150W and a 240w Charger Bricks
    any help would be appreciated !!!
    aconix likes this.
  2. aconix
    aconix Notebook Guru
    It is nice to see that you want to upgrade the beast instead of changing to a newer laptop.
    To run the 980m in this machine you will need obviously to upgrade your CPU to at least i7-920xm.
    However, as others have noted, heat and power are the principal issues for the 980m with 920/940xm processors near the limit.
    The best option would be the 970m but you will always need a CPU to avoid a huge battleneck, on aliexpress the i7-920xm for 30€.
    Also I would upgrade the PSU to 240w.
    We all wish you well - perhaps you will find a solution that has been missed, maybe a better heatsink for example?! One user tried once but failed.
    The last step is to modify the drivers but you have a lot of threads that explain the process and it not a complicated thing tho.
    The GPU 970m and 980m are with good price at the moment may be @EepoSaurus can help you since he had a 970m available some days ago.
    Keep us informed.
    Enviado do meu SM-N960F através do Tapatalk
  3. Duke Nukem Rayne
    Thanks for your Feedback , I bought A 240w Charger as a first step for 50$ , i ordered a i7 920xm processor from AliExpress 3 days ago , but because of the pandemic that we are living, it says it may be delayed for up to 3 months , :(
    I cant wait for the CPU to Arrive , also i ordered the gtx 980m last week from a local store here in my country , it should arrive very soon , i hade it for 220$ + shipping , :) ,i think its a good deal !!
    aconix likes this.
  4. aconix
    Awesome!! After tell us how it goes
    Duke Nukem Rayne likes this.
  5. CLASSIF1ED
    CLASSIF1ED Notebook Consultant
    bro you just got scammed, most if not all 9xxXM CPUs on aliexpress/from China are fakes.
  6. aconix
    Hey he bought through a local store not from aliexpress. Only the CPU was from aliexpress.
  7. saturnotaku
    He was talking about the CPU. o_O
    aconix likes this.
  8. aconix
    Ahaha you're right! I just saw 9xxm didn't think of the i7-920xm
    Regarding aliexpress I already bought a lot of cpu's without any issue
  9. Duke Nukem Rayne
    Good to hear that cause i will be waiting 3 months for it !!! the company that i ordered from looks legit with high numbers of good reviews and feedbacks
    so fingers crossed !!!
    aconix likes this.
  10. aconix
    No problem, if you have any issue just open a ticket and they will refund the money ASAP
