£90 for a DVD drive
Discussion in 'Hardware Components and Aftermarket Upgrades' started by TimDavies, Sep 17, 2008.
  1. TimDavies
    TimDavies Newbie
    The DVD drive in my Acer Aspire 3680 fails to read all DVD's and only intermittently reads CD's. It must be a problem with the drive as I can't even get it to read anything when booting, such as when putting in an installation CD/DVD.
    The only place I've found that sells DVD drive replacements sells them at £90 (~$180). That seems quite expensive to me, or is that a reasonable price for a laptop DVD drive?
  2. Andy
    Andy Notebook Prophet
    Try cleaning the lens.
    You can buy cheap ODDs from ebay such as the NEC ND-6650A....(I am using it in my 3680)
  3. naton
    naton Notebook Virtuoso
    The model you found must speak :D
    Too expensive. I sold couple of them in july for about £30 each. I still have one. I could sell it to you. It's a Pioneer DVD-RW DVR-K1RS. If interested just PM me.
  4. TimDavies
    TimDavies Newbie
    I've tried cleaning it with just a glasses cleaning cloth, is there any more thorough way of cleaning it?
    Thanks for the offer, I can't get my current one to work any better I'll PM you.
    Also, how specific are the parts? Does each part have to be made specifically for the laptop model, or do some parts fit, for example, not just my Acer 3680 but also other Acer models?
  5. Andy
    Checkout this post.
    Your notebook can use any Slim-Line IDE Drive, tray-loading or slot-loading.
    I have an Acer Aspire 3680 too, and I am happy with my NEC ND-6650A, because it is fast, and firmware/bootcode issues are not a problem.
  6. John Ratsey
    See this thread and the links therein for guidance on swapping notebook optical drives.
    Here are some (most probably) suitable optical drives. You can get three for your £90.
    John
  7. naton
    The only thing that you may have to change is the bezel (the plastic in the front of drive). Easy to do. If the new drie doesn't fit just remove the one from the old one and place it in the front of the new one.
  8. TimDavies
    TimDavies Newbie
    Thanks very much for the cleaning advice, but unfortunately it still doesn't work, and as MicroDirect is a company I've used before and I'm pleased with I'm going to buy a new drive from them. I think I'm going to go with this one http://www.microdirect.co.uk/(32257)Liteon-DVD-DS8A1P021C-slim---DL-DVD-RW-Black-oem.aspx
    However it says OEM on it, I know you should stay away from OEM versions of Windows, does it mean the same thing here?
    Thanks for all your help.
  9. Andy
    No, don't worry about OEM, but does it come with a warranty ?
    Also, does your notebook have an IDE or SATA HDD ?
  10. TimDavies
    TimDavies Newbie
    It's an IDE hard drive. Previous products I've bought from MicroDirect have had warranties, but I can't be certain if this one has, I can't find anywhere which says so for this particular item.
