Quantcast Kingston SSDNOW V200 Is Having Serious Performance Problems - Page 4
Page 4 of 26 FirstFirst 1234567814 ... LastLast
Results 31 to 40 of 251
  1. #31
    Jan 2011
    Edmonton, AB
    Default re: Kingston SSDNOW V200 Is Having Serious Performance Problems
    Maybe because it's CDM not ATTO? The figures given by Kingston are based on ATTO I think.
    Sony VAIO SB11FX
    | i5 2410M | 8GB | 64GB Crucial M4 + 80GB X25-M Intel G1 | Bigfoot Killer N 1102 |
    Fujitsu F-08A | NEC N-01C
  2. #32
    Retired
    Jul 2007
    The Netherlands
    That's valid for Sandforce drives. The Kingston V200 is based on JMicron.
  3. #33
    o TuNaY o
    Jan 2009
    Norway
    Quote Originally Posted by Phil View Post
    Yeah I don't suggest turning off pagefile but let's not have that discussion here. It's been discussed at length in the general SSD thread.
    Roger that.
    Last edited by Phil; 5th December 2011 at 05:10 AM. Reason: please use another thread for page file discussions
    MacBook Pro
    Intel Dual-Core i7 2.8GHz, 4MB, 1333MHz | 4GB Samsung DDR3 1333MHz | Crucial M4 128GB SSD | Intel HD Graphics 3000
    13.3-inch LED Backlight | 720p FaceTime Camera | MultiTouch TrackPad | Backlit U.S. Keyboard
    SuperDrive 8x (DVD±R DL/DVD±RW/CD-RW) | 60W PSU
    Mac OS X Version 10.7.3
    Apple iPhone 4S 64GB
    Unlocked | Glowing Backlit Logo (removed)
    iOS Version 5.1
  4. #34
    Nov 2011
    I'll go ahead and do a clean install and report back with my findings. If I get the same low readings I'll contact kingston. Could it be possible it is defective? Never had an SSD before so I would not know the symptoms.
  5. #35
    Retired
    Jul 2007
    The Netherlands
    It's possible that it's defective but it's more likely it's something else.
    PS. when you do the clean install make sure to remove all partitions during setup. I suggest to not do any tweaks.
  6. #36
    Nov 2011
    So basically when i install windows format the drive and install windows?
  7. #37
    Retired
    Jul 2007
    The Netherlands
    Delete all partitions, create one partition for the entire drive and quick format it.
  8. #38
    o TuNaY o
    Jan 2009
    Norway
    I usually format the drive and let the windows create the partition. But however, I don't think there is a diffrence.
    MacBook Pro
    iOS Version 5.1
  9. #39
    Jan 2011
    Edmonton, AB
    This is the footnote in the spec sheet.
    2 Based on “out-of-box performance” with ATTO Disk Benchmark 2.41. Speed may vary due to host hardware, software and usage.
    and the number 2 refers to sequential write.
    Sony VAIO SB11FX
  10. #40
    Retired
    Jul 2007
    The Netherlands
    OK. Well my point was JMicron, unlike Sandforce, doesn't use compression. So using CDM instead of ATTO shouldn't make any difference.
    Would be nice to try though.
    _____________
    Found some interesting stuff: Someone else that gets very strange performance.
    Kingston saying that the V200 128GB should get 257 points in AS-SSD.
