Results 1 to 10 of 59
Thread: Lowest power consumption SSD?
23rd June 2011, 06:42 PM #1Notebook Enthusiast
- Join Date
- Nov 2007
- Posts
- 33
- Rep Power
- 14
Looking for a SSD for my new X220
I'm considering 4 different SSDs at this time, Intel X25-M 120GB, Intel 320 120GB, Crucial C300 128GB, and Crucial M4 128GB.
Does anyone know which one of these four have the lowest power consumption?
23rd June 2011, 06:53 PM #2Banned
- Join Date
- Dec 2008
- Location
- YellowBrickRd.AU
- Posts
- 7,931
- Rep Power
- 0
Re: Lowest power consumption SSD?
Intel does better than Crucial. Samsungs tend to be the lowest.
24th June 2011, 03:25 AM #3
Samsung 470 for lowest idle consumption.
Intel 320-ssd: Power Consumption - Tweakers.net Reviews
24th June 2011, 08:23 PM #4
As it's been stated, out of those 4 you'd be best off with Intel. Crucial tends to be higher performance so battery life usually suffers. Also are you talking about overall power consumption or just idle or doing tons of I/O.
Alienware M17x R2 (Gaming DTR) : i7-920XM|16GB DDR3|5870 Mobility CrossFire|Samsung 840 Series 512 GB SSD|17.1" RGBLED WUXGA|7HP|Nebula Red
Sager NP8690 (Backup Gaming DTR): i7-720QM|8 GB DDR3|GeForce 280M|Samsung PM810 series 256 GB SSD|15.6" 1080p LCD|7HP
Backup server: Pentium G630|8GB DDR3|Gigabyte Z77-DS3H|Intel HD 2000|Samsung 830 64 GB SSD, 2 x Seagate 1.5 TB 5900rpm RAID 1|7HP|NZXT Source 210
Other Toys: '94 Acura Integra RS|Google/LG Nexus 4 16 GB| Dell Vostro 1500| Looking for an AT&T or unlocked GSM iPhone 4!
24th June 2011, 08:32 PM #5
intel or samsung.
sager np5160 - i7 2630 qm 2.0ghz, 8Gb ram, 540M, samsung830 256GB ssd, bluetoof, intel 6230, bd rom, shin etsu 7783d, win 7-64... i like it!
24th June 2011, 11:27 PM #6
Samsung 470, definitely. Phil also knows that I've checked a lot of reviews to buy the SSD with the lowest power consumption. The Samsung 470 has overall the lowest power consumption, better than the competitors from Intel and Crucial.
MacBook Pro 15" | Core 2 Duo 2.66GHz | 8GB RAM | Samsung 470 256GB SSD
24th June 2011, 11:51 PM #7Notebook Consultant
- Join Date
- Sep 2009
- Posts
- 138
- Rep Power
- 9
May I ask how important it is to comsume a fraction of watts more or less?
Does one as a personal user get significant benefit out of this less power comsumption.
For me it is pointless measure out of all SSD features and one should not take
power consumption rates into consideration as buying comparison.
Another pointless measure is MTBF from buyers perspective.Last edited by yalcin19; 25th June 2011 at 12:11 AM.
25th June 2011, 12:51 AM #8
Not at all. With ULV / thin and light laptops, every Watt counts. My M11x with IGP on consumes only about 7-8W idle/surfing. If I can idle at 0.2-0.3W instead of 0.8@-1.0W then I can save a good 30-60 minutes battery. I can get nearly 8 hours battery using my Intel 120GB X25-M G2 SSD compared with only 6.5 or so with the 7200RPM HDD that it replaced.
Sager NP9150 'Prometheus': 15.6" 1080p matte - i7-3740QM - GTX 680m - 16GB 1600 - 512GB+mSATA 256GB Crucial M4 - Blu-Ray
Sager NP6110 'Firefly': 11.6" 768p matte - i7-3610QM - GT 650m - 8GB 1600 - 500GB Samsung 840
Sager Reviews: UPDATED 5/9/13 NP6110 w/650m i5 vs i7 | NP9570 w/680m SLI | NP9370 w/ 680m SLI | NP9150 w/680m | PREMA'S CLEVO BIOS | MOD 680m vBIOS
My WHS 2011 | HP 6475b A10-4600m | All my other crap
25th June 2011, 01:19 AM #9Notebook Consultant
- Join Date
- Sep 2009
- Posts
- 138
- Rep Power
- 9
I personally got nothing out of it going from HDD to SSD. Possibly negligible
few minutes.
I have a 54000mW battery and it runs out in ~1.5 hours. That is 600mW per minute.
I can do some research on power usage of all the components and add them up and show you that is neglegible.
Maybe when I have some spare time I will do the calculations for you.
25th June 2011, 01:29 AM #10
Yes in that case it won't matter much. That's why I mentioned ULV and/or thin & light laptops and netbooks that sip power to begin with. It can garner well over an hour of battery life. I wouldn't consider the power consumption of an SSD in a desktop or desktop replacement like my Sager 17" because it would only run a matter of minutes difference.
In the case of my Hannspree notebook that I'm typing on right now, it has 55000 mWHr battery, draws about 9000mW so gives 6.1 hours battery life (55000/9000) which is about accurate with the SSD in there. If it drew 800 mW more that's 55000/9800 = 5.6 hrs battery life = half hour difference.
I have done tests between different SSD's and HDD's and can tell you for low power laptops it can make a significant difference.Last edited by HTWingNut; 25th June 2011 at 01:42 AM.
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 03:24 AM in Gaming (Software and Graphics Cards)
