| Sager and Clevo Clevo is perhaps not widely known, but their products are re-branded and sold by many known boutique brands. |
05-13-2008, 01:03 AM
#1
>>> SetFSB Auto Tool v2.1 <<< - OC your CPU automatically -
 v2.0
What is SetFSB?
SetFSB is a program that makes possible control the PLL(Clock Generator) on your board, so you can control the FSB and PCI/PCI-E buses while in Windows. That way you can overclock your CPU and system memory too.
What is SetFSB Automatic Tool?
I decided to make this tool, because when you shutdown(to power off/standby) all the settings that you have made within SetFSB are lost. Then you need to re-enter and re-setting the FSB again.
So with this tool you donīt need to do anything, it will set a predefined overclock automatically on systems boot.
Because the M570RUīs clock generator resets on shutdown(standby) but keeps its settings when you restart(the power is not cut), this tool will automatically detect that situation an will not rise the FSB again.
Every time your computers starts, the SetFSB Auto Tool will automatically apply the predefined overclock to your CPU. Remember to test first manually, if the overclock that you desire is stable. Only then your should use this tool.
If in the future your donīt want the overclock applied, just delete the .exe from the Startup folder. If you want any other speed just download the SetFSBAutoTool with the speed that you desire for your model, and apply it, starting from the step 2.
New Tool - SetFSB Auto Tool OC OFF - http://audigyapps.com.sapo.pt/SetFSBAutoTool_OCoff.rar
This new .exe will reset your CPU to stock speeds when overclocked. Just copy it to your desktop or any other place and double-click on it.
Code:
Release Notes:
12/5/2008 v1.0
- First release!
13/5/2008 v1.1
- Improved tool speed
- Minor bugfixes
- Improved restart detection argorithm
- Improved stability
14/5/2008 v2.0
- 100% new code
- Better support on diferent GUI DPI settings
- New OC OFF Tool released
16/5/2008 v2.1
- New installer, safer and easier to apply
*For version v2.2, new icons and some improvements...
Compatible with:
- Vista x86/x64
- XP x86/x64
I hope that this little tool will be useful to you, as it was for me...
* I tested it exhaustively, but if you find any bug or error, please report it in this topic.
Reason: New version v2.1 - New automatic installer - New OC OFF Tool - Updated CPU support list!
05-13-2008, 01:10 AM
#2
Banned
Re: >>> SetFSB Auto Tool v1.0 <<< - OC your CPU automatically -
did you just read my mind? lol I was just about to ask questions of this tool!! +rep!
05-13-2008, 01:21 AM
#3
Mastershake
nice.. i have my bios now showing the options to oc from it.. but they are greyed out?? im working on hopefully a way to do this directly from the bios.. but this tool def rocks. nice..
__________________
See my guide on how to make a bootable usb stick: http://forum.notebookreview.com/showthread.php?t=246530
laptop lol which one... we have 8 currently at home..
Meatwad you're up next, with your knock-knock.
Meatwad make the money see. Meatwad get the honeys G. Drivin in my car, living like a star ice on my fingers and my toes, and im a taurus
05-13-2008, 01:34 AM
#4
Wow.. bravo!! for this tool any luck with a Q6700 chip.??
__________________
Sager NP 9262
Q6700 (2.66GHz) - 4GB 800MHz RAM -2x160GB Seagate 7200rpm SATA-II HDD -2x 8800M GTX SLI with modded vgabios running at 600/975/1500 - WUXGA+ -vista Ultimate x64 SP1
3dMark06-SM 2.0 Score 4920-HDR SM3.0 6301-CPU score 3850-Total 13200
3dMark Vantage-GPU score 7256-Cpu Score 9461-Total P7715
05-13-2008, 01:40 AM
#5
Banned
I want to make it clear before i blow up my new toy, my t8300 able to OC to 3.0Ghz?
05-13-2008, 01:45 AM
#6
What about a T7700 at 2.4ghz? I didn't know there were different speeds for one cpu.
__________________
Intel Core2Duo @ 2.4GHz/core (T7700)
512mb GeForce 8600mGT
2GB Corsair RAM
160GB Harddrive
"Governments never do anything by accident; if government does something you can bet it was carefully planned.
(Franklin D. Roosevelt)
05-13-2008, 01:52 AM
#7
Banned
@vashts121, those 2.5Ghz to 3.0Ghz are our target speeds, select the one which you would like to OC at.
05-13-2008, 02:09 AM
#8
Hope this doesn't wear out my T7500. Thanks for the heads up. Never knew laptop CPU's were OC'able.
EDIT: Will this be OK for a DELL XPS M1530?
__________________
XPS M1330
T7100|1GB|Tuxedo Black|X3100|120GB|3945ABG
XPS M1530
T7500|3GB| Crimson Red|8600M GT|250GB|4965 AGN
3DMark06- 6087 Marks!! +175.19
05-13-2008, 02:38 AM
#9
I'm suddenly curious on how high you could safely push a T9300.
__________________
Flesh Peddler (Desktop): Intel QX6700 (@3.2Ghz)|EVGA nForce 680i SLI|2048MB Ram|Nvidia 8800GTX 768MB|2x 500GB 7200RPM, 1x 74GB 10000RPM
Prickly Bush (Desktop): Athlon 64 3000+ CG|ASRock K8S8X|2048MB Ram|ATI X1600 512MB|2x 200GB 7200RPM, 2x 80GB 7200RPM
05-13-2008, 04:30 AM
#10
Sounds good. +rep  I'll be waiting for the files for my T7300.
__________________
Sager NP5790 (ordered from XoticPC) [September 07]
17" WSXGA glossy screen (ie. 1680x1050)
C2D T7300 @ 2.00GHz --> upgraded to C2D T9300 @ 2.50GHz (OC'd to 2.65GHz) [April 09]
3GB RAM
8800M GTX 512mb successfully installed! [March 08] (from a 7950GTX)
160GB 7200rpm HDD
Win XP Pro SP3 (32-bit)
Mini Review (old)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
