Go Back   Laptop Forums and Notebook Computer Discussion > Notebook Manufacturers > HP, Compaq and Voodoo PC
HP, Compaq and Voodoo PC HP offers an array of notebooks to consumers under the Pavilion line, business notebooks under Compaq and gaming notebooks via Voodoo PC.
Welcome to NotebookReview.com! Have a Laptop related question?
Register and ask it here in the forums and remove this ad
Are you looking for a Lenovo laptop or special offers? Check out our Why Buy Lenovo? page
Reply
Thread Tools
Old 06-01-2007, 10:05 PM   #351
Calvin
Notebook Prophet
Calvin's Avatar
Rep Power: 34 Calvin has a reputation beyond reputeCalvin has a reputation beyond reputeCalvin has a reputation beyond reputeCalvin has a reputation beyond reputeCalvin has a reputation beyond reputeCalvin has a reputation beyond reputeCalvin has a reputation beyond reputeCalvin has a reputation beyond reputeCalvin has a reputation beyond reputeCalvin has a reputation beyond reputeCalvin has a reputation beyond repute
Default Re: High Pitched Noise from new Pavilions
Oh my god is this gonna affect my DV6000Z??? Now i'm scared.
Calvin is offline   Reply With Quote
Old 06-03-2007, 06:43 PM   #352
hcky11kec
Rep Power: 0 hcky11kec is an unknown quantity at this point
I just got the dv6000t Intel Core 2 Duo and had the same annoying noise. Luckily, HP has a fix on their website. If you have a newer BIOS, then just follow the steps for the BIOS SETUP, it worked for me! http://h10025.www1.hp.com/ewfrf/wc/g...reg_R1002_USEN
hcky11kec is offline   Reply With Quote
Old 06-04-2007, 07:44 AM   #353
cooptrupp
Rep Power: 0 cooptrupp is an unknown quantity at this point
new firmware F25, again much less noice
http://h10025.www1.hp.com/ewfrf/wc/s...s=2093&lang=en
cooptrupp is offline   Reply With Quote
Old 06-05-2007, 04:08 AM   #354
dizbmikuni
Rep Power: 0 dizbmikuni is an unknown quantity at this point
Is it a significant noise reduction over the F16 BIOS? Also, can you notice any battery life differences?
dizbmikuni is offline   Reply With Quote
Old 06-05-2007, 06:57 AM   #355
mbmalone
mbmalone's Avatar
Rep Power: 8 mbmalone is new here but already liked
I updated, lets hope for less whine.
mbmalone is offline   Reply With Quote
Old 06-05-2007, 11:34 AM   #356
cooptrupp
sometimes its completly quiet, and sometimes it whines. but c4 is enabled. so its good. have not tryed yet disableing couse it starts heating more and so the fans becomes louder.
Old 06-07-2007, 07:34 AM   #357
nickbarbs
Rep Power: 10 nickbarbs is a jewel in the roughnickbarbs is a jewel in the roughnickbarbs is a jewel in the rough
Guys!! I did not read through this thread but i found it on google. Go into your BIOS and DISABLE C4 CPU or whatever iteration of that as it is called in your bios settings and restart your PC. No more high pitched noise. Dv9339us here... noise went away after doing that. Apparently you lose about 10% batterly life, so just enable it when you're on the road and deal with it. this is my first HP coming from DELL and let me tell you, so far this pc trumps any experience I have had with a dell laptop. Those things are complete cr@p.
nickbarbs is offline   Reply With Quote
Old 06-07-2007, 02:04 PM   #358
kubel
Rep Power: 11 kubel will become famous soon enough
Quote:
That might work for Intel based Pavilions, but disabling power management on AMD based Pavilions has an opposite effect, and in my experience, contributes to VGA out interference.
__________________
Asus Eee PC 900HA
Atom N270, 2GB RAM, 8.9", 128GB G.Skill Titan (first RAID-0 SSD equipped netbook)
Asus Eee PC T91MT
Atom Z520, 2GB RAM, 8.9" Multitouch Touchscreen, 32GB SSD, broken already :(
kubel is offline   Reply With Quote
Old 06-07-2007, 02:45 PM   #359
HP_Total_Care
Rep Power: 8 HP_Total_Care will become famous soon enough
Hi, it’s Anna from HP Total Care,
I’m sorry some of you have had trouble with that high pitched noise coming from your notebooks. Go to http://h10025.www1.hp.com/ewfrf/wc/g...reg_R1002_USEN to find out more information about what can be done. Note: this is ONLY applies to notebooks with Intel processors.
This BIOS may have an impact on your battery life, so below are some ways to conserve power.
Some features that can eat up battery life are the glass transparency and Aero displays. You can deselect them through the following process:
Right click on a blank area of desktop.
Select Personalize from the context menu.
Click Window Color and Appearance Option. Here, you can check or uncheck if you want to Enable Transparency or not. You can also disable the whole aero glass theme from here. Just click the link at the bottom that says “Open classic appearance properties for more color options.”
Select a non-Aero theme and click OK.
Here’s tip number 2:
Click on the start/pearl icon and type in the word “performance.”
Choose Performance information and tools.
Click on Adjust visual affects.
A box will likely pop up to get your permission to continue. Click Continue.
Choose the option that says Adjust for best performance.
Here’s tip number 3, which will stop HP Total Care Advisor from launching whenever the PC is booted up:
Click the “wrench" icon in the upper right corner of the HP Total Care Advisor display—that will get you to the Preferences page.
Under General Settings, click the checkbox to uncheck the Launch HP Total Care Advisor automatically on start-up—that will deselect that option.
Click OK, then you’re done.
I hope this is helpful.
Anna
HP_Total_Care is offline   Reply With Quote
Old 06-07-2007, 08:44 PM   #360
dizbmikuni
Anna
We have recognized previously that disabling the c4 function does reduce the high pitched noise. However for many of us, it does not reduce it enough and is still very annoying. Some people have stated that they have sent in their notebook for repairs regarding this problem. Could you give us any information on what the problem was diagnosed as and what steps were taken to fix it? Thank you for your help, it's nice to see someone from HP taking notice of a very widespread problem and addressing its customers directly.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
TechTarget Corporate Web Site  |  About Us  |  Advertising  |  Site Map  |  Contact Us  |  Submit Review  |  RSS Feeds  |  Jobs
All Rights Reserved, Copyright 1999 - 2007, TechTarget | Read our Privacy Policy
  TechTarget - The Most Targeted IT Media
