Quantcast Possible Solution to high idle Fan RPM!
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Apr 2012
    Default Possible Solution to high idle Fan RPM!
    Well seeing as so many of you are complaining about the fans, i will share my solution with you. This solution is not proven by any means but works for me.
    1. start msi afterburner
    2. play your game of choice
    3. exit the game and wait 5-10 secs for gpu to cool down
    4. in msi afterburner hit the "K" tab on the left to start Kombustor.
    5. After 1-2 seconds the fans should go silent, when they do close Kombustor
    this method works perfectly for me, if it doesnt try to close afterburner and open it again and repeat step 4.
    I do not know if this method damages your GPU, so im not responsible for any damage you cause by trying this.
    Note: my afterbuner temp. graph is well under 50, so i think im safe.
    PCS Vortex III: (P150EM)
    Intel i7 3920XM | NVIDIA 680M | 256GB Samsung 840 Pro SSD | 1TB WD Scorpio Blue HDD | 8GB Samsung RAM
    Crossover 27Q LED-P @1440p
  2. #2
    Feb 2011
    Portugal
    Default Re: Possible Solution to high idle Fan RPM!
    This actually seems consistent with my thoughts on the fan problem: when Optimus/Enduro switches to the integrated GPU, the dedicated one probably is completely "ignored", and leaves its fan exactly as it is at that moment.
    I'd say it's a bad BIOS coding, maybe.
  3. #3
    Dec 2010
    I think the fan keeps running is becuase you have GPU monitoring program on, the GPU will rotate between default clock and idle clock when the dGPU is being monitored, you have to make sure all GPU monitoring programs are off if you don't want to use the dGPU. And slight usage (monitoring too) will prevent the dGPU from shutting down. Also the GPU temp in ThrottleStop will prevent the dGPU from shutting down too.
    Lotus P150EM SE (Clevo P150EM)
    Actual: 15.6" FHD LED 95% NTSC Matte | Intel i7-3740QM | NVIDIA GTX 680M (new card arrived) | 16GB 1600MHz | Samsung SSD 830 256GB|
    P150EM Upgrading from 675M to 680M!
  4. #4
    Apr 2012
    well if i dont monitor, the fans just keep spinning.
  5. #5
    Sep 2009
    overseas
    yes,kombustor can turn off the fan at idle if temp is below 49C
    ASUS G75
    3610 8GB 2xSSD GTX670 Bluray
  6. #6
    Dec 2010
    Try open up CCC when all monitoring program are off, when I open up nvidia control panel on the GTX675M/GTX680M the fan turns off instantly when temp is below 45C.
  7. #7
    De-evolving to Amoeba
    Oct 2011
    Limbo
    Default
    This also happens with HM models. It would have been good if the EM had been updated with better fan control.
    P150HM | i7-2720 | AMD 6970m | 8GB 1600 RAM | 256GB Samsung 830 SSD | 500GB WD | Arctic MX-4
  8. #8
    Jun 2010
    Quote Originally Posted by crosslimit View Post
    Does double-tapping Fn + 1 do the same thing as the kombustor trick? (if Fn + 1 is enabled on your PC)
  9. #9
    Apr 2012
    Quote Originally Posted by arg8 View Post
    the FN+1 combo doesnt work for me sorry...
    but i will try firing up CCC after a session
  10. #10
    Sep 2009
    overseas
    Furmark also work for me
    ASUS G75
