Results 11 to 20 of 22
18th August 2011, 03:00 AM #11
Re: x8100 with 485m weird problem it works but 2 beeps are reboot
In my case, with one GTX580M OC (OV), the maximum power consumption during 3DMark Vantage test is over 220 Watts.
18th August 2011, 11:08 AM #12Notebook Consultant
- Join Date
- Feb 2011
- Posts
- 277
- Rep Power
- 7
what is your laptops rated TDP, as for the p180hm it's going to be 220 watt's as well, same power adapter and everything, i'm just hoping the bios recognizes the card(it should), and what i really hope is that my HEAT related issues are done,
18th August 2011, 11:34 AM #13
My AC adapter has a 180 watts of rated power. But it can provide for few seconds a little more (220).
http://img718.imageshack.us/img718/3603/dsc0175y.jpg
18th August 2011, 12:15 PM #14Notebook Consultant
- Join Date
- Feb 2011
- Posts
- 277
- Rep Power
- 7
you ran vantage and hit 220 of the wall? with a voltage meter? how long did you run the test and did you crash or shutdown at some point? what temps btw
18th August 2011, 01:29 PM #15
220 watts is the maximum value, attained by only a few seconds during the test 3DMark Ventage with OC 800/2000. For 3DMark11 maximum input power is much lower (180 watts) and allows for up OC to 860/2000.
The maximum temperature does not exceed 89 C
18th August 2011, 03:37 PM #16Notebook Consultant
- Join Date
- Feb 2011
- Posts
- 277
- Rep Power
- 7
thats good for stress testing temperatures in a "laptop", but your overclocking so that affects your wattage, nether the less i strongly believe 220 watts is adequate, almost certain at this point. Now to await for a p180hm motherboard ....
19th August 2011, 09:58 AM #17
19th August 2011, 11:36 AM #18Notebook Guru
- Join Date
- Dec 2010
- Posts
- 73
- Rep Power
- 6
but we Chinese simply think it's a trick of CLEVO
they fear about the GPU card upgraded by yourself on the older type of their notebooks.
so bios/ec or some other things maybe wrong ?
860 could upgrade to 6970m(es , equal to 6990m) but gtx560m will meet a black screen
that's all , we also Helpless but an amd card will solve this problem .
please upgrade to 6990m-crossfire-X and everything will be fine .--- naked w860cu made by Clevo---
920XM(Q3B8-26/24/20/20@75w) - GTX470m 675/1500/1350@0.94v
SOLIDATA-K5-SLC-64G
Win7 7.4 - 7.5 - [ 7.5 - 7.5@verde285.27 whql ] - 7.3 @ 180W AC ( HP / weight:904g / 5.5*2.5 )
14th April 2012, 12:17 PM #19Newbie
- Join Date
- Apr 2012
- Posts
- 3
- Rep Power
- 0
lzykocp1002,
Did you ever get the 485 working well with both ram sticks installed? I've got a x8100 I'm trying to get working with a 580m, and I have the exact same symptoms (two beeps at boot, no video). Unfortunately, I don't have a 2Gb stick of SODIMM to try- just two 4GB.
Regards,
Jared
14th April 2012, 01:15 PM #20
It's the NVRAM that is getting corrupted because of values not properly written after first shutdown...the easy way to workaround would be to detach the cmos battery for good...
as for the SLI, it is something that has to be present in the BIOS for that specific card, so it properly reports to the OS...Everything has a price!
The price to be paid for enduring happiness is Divine Love.
Without Love, no object can give you real happiness!
PREMA'S BIOS MODS
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 02:21 PM in Gaming (Software and Graphics Cards)
