Quantcast d990f from sager: headphones jack no sound output?!
Results 1 to 3 of 3
  1. #1
    Oct 2009
    Default d990f from sager: headphones jack no sound output?!
    I bought my sager 9280 last year october.
    today I turned on my notebook and for some reason there is no audio output through the headphones jack anymore.
    I tried my extra speakers and two different headphones: no sound. the system still tells me that I plugged something in, but no sound. without anything plugged in the notebooks speakers play everything fine.
    Yesterday the sound output thourgh the headphones jack worked, today it doesn't.
    Can anybody think of reasons?
    What can I do to fix this?
    thanks in advance,
    brato
    oops, d900f of course. typo in the title, sorry for that.
    Sager 9280 (Clevo D900F)
    Intel i7 950
    6 GB RAM
    2x 500 GB 7200 HD RAID 0
    NVIDIA GTX 280
  2. #2
    Cyber Daemon
    Jun 2008
    Deep Space
    Default Re: d990f from sager: headphones jack no sound output?!
    2 years ago, I had a very similar issue on my Clevo D901C (the predecessor model to the Clevo D900F), even the message that something is already plugged in into the jack.
    No solutions seemed to work.
    Uninstalling and Reinstalling the Audio Driver solved the problem for me, it can be found in the "Drivers and Utilities" disc that came with your Sager Laptop, this is probably the most straight-forward solution.
    Apple iMac 21.5" - Intel Core i5 @ 2.5 GHz - AMD Mobility HD 6750 - 4 GB DDR3 @ 1,333 MHz
    Dell Inspiron M5030 - AMD Athlon II P340 @ 2.2 GHz - AMD Mobility HD 4200 - 3 GB DDR3 @ 1,066 MHz
    Sager Notebook NP9262 - Intel Core 2 Quad @ 2.67 GHz - Nvidia 8800m GTX SLi - 4 GB DDR2 @ 800 MHz (Defunct)
  3. #3
    Oct 2009
    thank for your help.
    now, the next morning and after a restart it works again but I do not know why. I should have tried re-starting the system yesterday (but why restart right after booting up?).
    well, let's hope it keeps working. I wish I'd know what's going on though.
    Intel i7 950
    6 GB RAM
    NVIDIA GTX 280
