Quantcast Running external monitor, mouse & keyboard
Results 1 to 9 of 9
  1. #1
    Cranky Bastage
    Apr 2008
    Central Indiana
    Default Running external monitor, mouse & keyboard
    I'm guessing this is the right place for this question, as it strikes me as a dumb one, but it's something I've never considered.
    When connecting an external monitor, mouse and keyboard to a laptop, I assume that I can set it not to suspend when I close the lid. I also assume that by doing so, not only will I be able to continue working using the external peripherals, but will also be able to operate the internal devices such as the optical drive, card readers, etc, and that basically the machine will still function normally. Is all that correct?
    ThinkPad T500 2081-CTO:
    T9400, 4GB DDR3, 15.4" WSXGA+ TFT CCFL with camera, ATI Mobility Radeon 3650 256MB GDDR3, 160GB 7200RPM HDD, Ultrabay Slim DVD R/W, ExpressCard/PC Card, fingerprint reader, AT&T WWAN, Intel WiFi Link 5300, 9-cell battery
    Laptops I've owned in the past:
    HP 6710b | Dell Inspiron 6000D | Toshiba Satellite 5105-S607 | IBM ThinkPad A20m | IBM ThinkPad 570E | IBM ThinkPad 600E | Compaq Armada 1750 | Gateway Solo 2100
  2. #2
    Advocatus Diaboli
    Jan 2008
    Switzerland
    Default Re: Running external monitor, mouse & keyboard
    well, on my laptop, i can change a setting in the power management so that if i close the lid, nothing will happen/change/turn off.
    Lenovo T410 14.1" | 2.66GHZ | 1440x900 | NVS 3100M | 4GB DDR3 | 250GB SSD | Windows 7 64bit
    Alienware m15x 15.6" | 2.5GHZ | 1440x900 | 8800M-GTX | 4GB DDR2 | 160GB HDD | Windows 7 64bit
    Gear Zalman NC2000 | Mionix NAOS 5000 | ROCCAT Taito | 1TB WD Elements | Apple iPhone 4S 16GB
  3. #3
    Cranky Bastage
    Apr 2008
    Central Indiana
    Thanks. That's what I figured.
  4. #4
    Jan 2009
    Be wary though, my old laptop heats right up doing this as a fair bit of heat is dissipated up through the keyboard and palm rest area - with the screen down it has nowhere to go and heats up at an alarming rate.
    Why not keep it open and dual screen?
  5. #5
    Dec 2008
    Warner Robins, GA
    just my .02 here, but why not buy a docking station or port replicator? It saves on plugging stuff in all the time. However, if you do go into the power settings and change the "when i close the lid" option, you'll be able to do what you'd like just like Whizzo mentioned. i personally haven't heard of any heating issues while doing this, and if your video card will support the dual monitor option, that's always a cool option to have.
  6. #6
    Sexy member
    Aug 2008
    Canada
    Why not close the lid almost all the way so that there's still a bit of space? Like maybe 10 degrees from the keyboard?
    And yes, with Vista you just change the power settings so closing the lid does nothing.
    Cheers,
    Fred
    Dell XPS 13
    October 2012 | Win 8 Pro | i5 3317U | 4 GB | 128 GB | Intel 4000 | 1366x768 | WiDi
    Microsoft OneDrive - 7.5 GB promo
  7. #7
    Jan 2009
    For me, I choose to close the Lappy's lid when connected to the monitor. Just feels natural.
  8. #8
    Notebook Prophet
    Aug 2007
    Chicago, IL
    Its fine to close the lid. Ever see a docking station with a laptop in it at any business. They are all closed...
  9. #9
    Jan 2009
    Quote Originally Posted by hsbsitez View Post
    working with monitor and laptops looks natural
    this is reason why I'm looking to get bigger laptop than standard one.
SEO by vBSEO 3.6.1
