Results 1 to 2 of 2
Thread: wi fi beginer help
14th January 2007, 01:16 PM #1Newbie
- Join Date
- Jan 2007
- Posts
- 4
- Rep Power
- 0
wi fi beginer help
am pretty new to laptops and wondering how to use wi fi.
am using a advent 7016 laptop
do i need to use a network adaptor or can i just use wi fi to connect to the internet, would it pick my wireless router up and if so how.
14th January 2007, 02:09 PM #2
Re: wi fi beginer help
Does your laptop have integrated wireless (or a wireless card)? If it does and you have a wireless router, then you can connect wirelessly.
You should review your router's instruction manual and your wireless manual. After that, you should look around a little bit in this board, as there are tons of tutorials on how to set up a wireless network.
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 02:14 PM in Gaming (Software and Graphics Cards)
