Quantcast HOW TO: Switch between Static and Dynamic IP?
Results 1 to 3 of 3
  1. #1
    Apr 2006
    Default HOW TO: Switch between Static and Dynamic IP?
    I have a Static IP set up for my notebook on my home network. I did this in order to get better download speeds.
    Now when I connect to the network at school I need to change my settings to "Obtain IP Address Automatically" which deletes my previous Static IP settings.
    How can I change between both Static and Dynamic IP without needing to retype my Static IP everytime?
    Thanks,
    Mike
  2. #2
    qhn
    qhn is offline
    Notebook User
    May 2006
    Default Re: HOW TO: Switch between Static and Dynamic IP?
    how about set.up a 2nd connection? then u'd have one with static and the other with dynamic, just a matter of disable and enable
    cheers ...
    m6805 @3700 & sz71WN/C & macbook 2ghz - 4/250gb - superdrive & 7811FX
  3. #3
    Cooler and faster...
    Mar 2005
    Zagreb, Croatia
    go to network settings and set it to obtain the address automatically. Once you do it there will be another tab with Alternate connection tag. there you can enter your static address.
    The point of this is that everytim the comp asks for IP, it will try dynamic first, and if it doesn't find it, it will try your static address. Meaning - it always works.
    Cheers,
    Ivan
    ACER 8942G|Intel Core i7 Q720|4 GB RAM|ATI 5850 1GB DDR3|Kingston 80GB SSD + WD 320GB|18,4" Full HD screen
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
