Quantcast wireless linksys help
Results 1 to 6 of 6
  1. #1
    Jul 2006
    Default wireless linksys help
    hi, after installing the cd that comes with the software "wireless - G Broadband Router, Linksys 2.4GHZ.
    wat else do i do next to enable the wireless connection ?
    cuz right now if i unplug the cable , it wont let me connect to the internet.
  2. #2
    NBR Reviewer
    Mar 2006
    Default Re: wireless linksys help
    try going to 192.168.1.1 or 192.168.2.1
    I cant remember which is the default for linksys, and look at the settings. If it asks for a password and login, its probably "admin" an pw "password" check the owners manual.
  3. #3
    Zero Cool
    May 2006
    In Union station hacking the Gibson
    192.168.1.1 is the default. keep the plug in and open a IE window and in the address bar type in 192.168.1.1. Then a username and password prompt will pop up. Skip to the password and typ "admin" and it will let you in. After that look for a wireless tab and enable wifi, also look for encryption and use WPA type in a password and you should be done. Also make sure the SSID is something youll recognize when roaming for hotspots at home. When you find yours it will prompt you for a network key and enter the password you made for the wpa encryption.
    If you are still not getting internet make sure your router is pulling an IP from the ISP. That will be under another tab in the router interface. just select release and renew.
    Main Rig: Sager 8298 4810MQ, GTX 880m, 256GB msata, 750GB and 1TB HDD, 16GB Ram 7 Pro
    SOLD: Alienware 14 - 4700QM, GTX 765M, 8GB RAM, FHD+ IPS, 256GB mSata + WD Scorpio Black 750GB 7 Ultimate
    Main server: Dell precision m4600 - 2860QM, firepro 5950, 16GB 1600mhz RAM 9-9-9-28, WLED FDH+, Intel 520 240GB mSata OS, Seagate hybrid 750GB storage.
    in limbo: Dell precision m4400 Debian squeeze
    Future Home Gym: Vostro 1700 WUXGA!
    In limbo: Thinkpad x200s
    My Youtube Channel!
  4. #4
    Jul 2006
    when i go on that webpage, it wont allow me to save settings, and an error is located at the bottom of the webpage.
    wat to do ?
  5. #5
    Zero Cool
    May 2006
    if the router's firmware wont accept the change then I would call cisco/linksys to see what they have to offer.
    My Youtube Channel!
  6. #6
    Jul 2006
    nvm, i had the firewall on, sry guys.
    but thx for telling that ip web address, i got it set up.
    once again , thanks very much, i appreciated
SEO by vBSEO 3.6.1
