Quantcast Question about wireless cards...
Results 1 to 6 of 6
  1. #1
    May 2012
    Default Question about wireless cards...
    Is upgrading the wireless card in the sager np9150 from the stock one to the intel Ultimate-N 6300 worth it. What exactly will an upgraded card do for me.
  2. #2
    Sep 2008
    Default Re: Question about wireless cards...
    I moved this to the wireless forum. What is the stock card on the NP9150?
  3. #3
    May 2012
    oh sorry didn't see that there was a networking and wireless subforum my bad. All it says on Xotic's site is Sager - Built-in 802.11 Wireless B/G/N - Stock Wireless Card + Bluetooth.
  4. #4
    Sep 2008
    Knowing what chipset the stock wifi card uses would help if you want to know what an upgrade would do. If it's a wifi + bluetooth combo card you will lose bluetooth if you get a 6300. The 6300 will have the possibility of using 3 antennas which will give you a bit more stable wireless versus 2 antennas.
    There are bluetooth combo cards made by intel like the 6230, 6235, 6250.
  5. #5
    Notebook Demon
    Jun 2010
    For Intel's, look for any xx3x if you want the bluetooth combo.
    The 6250 doesn't have bluetooth but has support for Wimax/4g
    HP dv6t-3000 CTO Select Edition - Intel i5-520m, 8GB DDR3, AMD Radeon 5650m,
    Intel Wifi 6250 ABGN (2.4Ghz/5Ghz). Windows 8 Professional x64 / Fedora 18 x86
    Dell XPS 15 R2 - Intel i7-2630qm, 6GB DDR3, Nvidia Geforce GT 540m,
    Intel Wifi 6230 ABGN (2.4Ghz/5Ghz). Windows 8 Professional x64
  6. #6
    Sep 2008
    Oh, sorry, not the 6250. I am having a hard time finding out what the stock card in the np9150 is for sure, it may be the 6230. In that case, the upgrade may not be worth it unless you are not going to need bluetooth and use wireless networks that have low signal/long range.
