Results 1 to 10 of 18
2nd May 2012, 08:27 AM #1
how can i reach the wifi network at work?
Hi
somewhere in this forum i asked a question about which wifi card i should get and was told that the intel 6300 or bigfoot killer is the best for range as they have a 3x3 antenna or something along those lines? I cant find how to access my older post here....
Anyway ill get on with it i have a few questions, do the different cards have different antennas included with them or do they all use the same one included with your laptop?
I have a wireless internet connection where i stay at work but its about 500-600m away so my wireless card in my acer at the moment will not even pick it up is this possible with any of these card upgrades?.
Will putting in a intel 6300 allow me to pick it up or will i need an external antenna?
I would love to be able to acess this free internet from my room and save me paying $40 per month for 5gb of 3g data.
Thankyou all
2nd May 2012, 08:59 AM #2
Re: how can i reach the wifi network at work?
The 3x3 antenna on the Intel 6300, or any 3x3 card for that matter, isn't meant for range. It's for higher speeds.
If you're looking for long range look at a high-end Atheros or Killer WiFi card with beamforming. Though even with beamforming I doubt you'll get 500-600ft of usable range out of any internal WiFi card. The max is usually around 300ft.
Also, the cards themselves only have hookups for the antennas that are already inside your notebook. Any card you put in will use the same antennas.
So if you need serious range, I'd say your best bet is a high-powered external directional WiFi adapter/antenna combo.AD NOCTVMMBP 15"
Dell Latitude E6220
Dell Vostro 3360
Galaxy S i897, i747, i777 | Galaxy Note II | iPhone 4S | Motorola Atrix 4G |
4th May 2012, 08:25 AM #3
Thanks mate so what exactly does 3x3 etc mean just better speeds? So I will notice no gain in range with the 6300 over a standard Bluetooth combo?
4th May 2012, 09:46 AM #4Notebook Evangelist
- Join Date
- Nov 2011
- Posts
- 609
- Rep Power
- 6
That is quite some range to get internet unless you got a wiimax or external wifi antenna attached to your laptop to maybe catch that signal at that distance. And let alone they give you permission....
This is the odd part free internet from your work place? I highly doubt they let anyone including employees get free internet on their network. I am saying that this is their property and unless you have access or permission I doubt they will just give that out for you just to have free internet?? Highly unlikely in any business model. I will say this because something here just doesn't add up here....unless you can state otherwise..... Why because anything you do on their internet or networks they will be responsible and if you use if for anything besides work they will be responsible for your actions and all the legal problems.
5th May 2012, 08:18 AM #5
so basically only chance i will have is with a large external antenna?That is quite some range to get internet unless you got a wiimax or external wifi antenna attached to your laptop to maybe catch that signal at that distance. And let alone they give you permission...
Are there any gains in distance with an intel n6300?
No im not doing anything dodgy or illegal..... must be the tattoos ehThis is the odd part free internet from your work place? I highly doubt they let anyone including employees get free internet on their network. I am saying that this is their property and unless you have access or permission I doubt they will just give that out for you just to have free internet?? Highly unlikely in any business model. I will say this because something here just doesn't add up here....unless you can state otherwise..... Why because anything you do on their internet or networks they will be responsible and if you use if for anything besides work they will be responsible for your actions and all the legal problems.
I work in a remote mining area and stay in a camp with public wifi that is free and available to all employees, only problem is that the camp has expanded beyond the reach of the wifi network so those who have rooms close to the kitchen and bar have free wifi, but those in the new construction rooms do not, unfortunately they are not upgrading the service to all rooms untill september.
5th May 2012, 11:05 AM #6Newbie
- Join Date
- Apr 2012
- Posts
- 1
- Rep Power
- 0
Sept is only 4 months away, am going to guess if u want this to work NOW, you are going to spend nearly enough to cover the $40 and the priviledge of the hassle.
5th May 2012, 05:46 PM #7Notebook Evangelist
- Join Date
- Nov 2011
- Posts
- 609
- Rep Power
- 6
That basically it unless they have a repeating tower that is to far of a range to go wifi unless they use wiimax....
That's good to hear. But like my reply unless they built or make a repeating tower or antenna near your location to catch back to the main free wifi location you won't be able to use it. And will have to wait til they upgrade your campus to get you on the wifi network unfortunately....
5th May 2012, 05:59 PM #8
even a external antenna probably is not gonna help it for 500-600m if the company signal is just plain normal 2.4ghz.
http://www.anandtech.com/show/4590/b...vs-the-world/7
the 6300 get like 200feet range .. if a external antenna even do "5x" better that is only 1000 feet which is like 300m.
typical external external is like 1.5 to 3x of laptops one iirc.Dell M6600 : DIY RGB LED IPS / i7-2670QM / M8900 / HyperX3K 120GB / 26GB DDR3 1333 / Mass slots which I don't know what to do with. ll U2711 U2312HM DIY LP173WF3(SL)(B1) B156HW01 v7
HP DV6z DV6t Asus K53TA Lenovo T61 G530 Dell Vostro1500
Playback: LAV -> ffdshow raw(deband/lsfmod) -> madvr(jinc3 AR)
Docomo Prime SH-10C : Pink 3DASV 16MPCCD IPX5/IPX7
5th May 2012, 07:19 PM #9
500m is really, really far for a wifi signal. 100m would be serious effort and would require either very expensive components or a custom built directional antenna.
500m+ isn't a practical wifi range unless you have open space and a very large custom directional antenna on both ends. By "very large" I mean satellite shaped antennas on both ends that are at least 6 feet off of the ground, with about a 2 ft radius, facing each other on either end.Ye Ole Macbook Air | Yonder Gaming Desktop
5th May 2012, 10:33 PM #10NBR Super Moderator
- Join Date
- Jul 2006
- Location
- NBR Moderator HQ
- Posts
- 16,271
- Rep Power
- 89
I don't really see how you can do this without some sort of dish
. This might work.
Desktop 13.3" Macbook Air W7 Ultimate, Core i7 2600k, Crucial M4 128GB SSD
8GB RAM, GTX 680, 3x Dell U2412M SurroundSnow Leopard, 1.86GHz, 2GB RAM
128GB SSD, iPod Touch, 32GB iPad
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 04:03 PM in Gaming (Software and Graphics Cards)
