Results 11 to 18 of 18
5th May 2012, 10:34 PM #11
Re: how can i reach the wifi network at work?
See, I read that as FEET. Not METERS. LOL.
If it's 500-600 meters, forget it. It's pointless. You'd need industrial grade, long-range, high-power directional antennas. 1800ft is a long way.
EDIT: You also said you're in a mining camp, that's also in a remote location... you have to factor in environmental variables when calculating range. Geography plays hell on wireless signals.AD NOCTVMMBP 15"
Dell Latitude E6220
Dell Vostro 3360
Galaxy S i897, i747, i777 | Galaxy Note II | iPhone 4S | Motorola Atrix 4G |
5th May 2012, 11:48 PM #12
Dell M6600 : DIY RGB LED IPS / i7-2670QM / M8900 / HyperX3K 120GB / 26GB DDR3 1333 / Mass slots which I don't know what to do with. ll U2711 U2312HM DIY LP173WF3(SL)(B1) B156HW01 v7
HP DV6z DV6t Asus K53TA Lenovo T61 G530 Dell Vostro1500
Playback: LAV -> ffdshow raw(deband/lsfmod) -> madvr(jinc3 AR)
Docomo Prime SH-10C : Pink 3DASV 16MPCCD IPX5/IPX7
6th May 2012, 02:20 AM #13NBR Super Moderator
- Join Date
- Jul 2006
- Location
- NBR Moderator HQ
- Posts
- 16,271
- Rep Power
- 89
The only reason I remembered it ... the only review I ever read on it?
Super Cantenna Review -- Extend Your Wi-Fi Network Range (pics)
That being said I'd still give it a healthy dose of skepticism and buy it from somewhere that allows returns.Desktop 13.3" Macbook Air W7 Ultimate, Core i7 2600k, Crucial M4 128GB SSD
8GB RAM, GTX 680, 3x Dell U2412M SurroundSnow Leopard, 1.86GHz, 2GB RAM
128GB SSD, iPod Touch, 32GB iPad
6th May 2012, 06:18 PM #14Notebook Consultant
- Join Date
- Apr 2012
- Posts
- 170
- Rep Power
- 3
10th May 2012, 12:17 AM #15
update:
I just stepped it out the other day and it is actually closer to 150 meters
, so going by what others have said about its range being 300ft then it still would not be possible without an external antenna setup.
still id love to know.... (nothing to do with this experiment), if a intel 6300 will give any improvement on range over a standard wifi combo, or are the only benefits the speed?
10th May 2012, 03:33 PM #16
For just range improvements you'll want a new Atheros card. They have higher Tx power ratings, and it shows.
I can go much further on my AR9380 than I could on my Intel 6205. The Intel 6300 won't fare much better than the 6205 in range... just throughput within the same range.
But I doubt even the AR9380 would go over 300 ft.AD NOCTVMMBP 15"
Dell Latitude E6220
Dell Vostro 3360
10th May 2012, 08:20 PM #17Notebook Evangelist
- Join Date
- Nov 2011
- Posts
- 629
- Rep Power
- 6
It might or might not work as I myself had tried that by putting my AR9380 into my hp dv4,dv5 and it bulked saying not recognized network card on bootup so I went with the intel 5100. So there is some limitations as to what network wifi you can place in laptops because of chipsets and laptop manufacture as I found out.
10th May 2012, 08:58 PM #18
There are actually specific versions of the AR9380 that are just for HP machines.
But yes, you need to know what WILL work vs what WON'T work with your particular brand of laptop. If it's a Dell, any card that will fit in the slot will work. HP, Lenovo and Toshiba all whitelist WiFi cards in their BIOS, and if it's not a very specific card... the laptop won't even boot at all. Like, no BIOS or anything. No POST.AD NOCTVMMBP 15"
Dell Latitude E6220
Dell Vostro 3360
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Yesterday, 02:21 PM in Gaming (Software and Graphics Cards)
