Quantcast Intel WiFi Link 1000 BGN issues - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    NBR Super Moderator
    Oct 2005
    Secret Laboratory
    Default Re: Intel WiFi Link 1000 BGN issues
    There's not much you can do but start with setting your Wi-Fi channel width to 20MHz (not 40MHz or auto).
    If that isn't enough try using channel one (signal strength difference there seems bigger than on channel 6)
  2. #12
    Nov 2011
    Ok when i comes down to network settings and stuff im kinda moronic lol... umm how do i do that?
    Edit: ok I went into properties and checked 802.11n channel width for band 2.4. It was already set to "20MHz only" I changed the channel in my router settings to 1 and now my speeds are slower . 1-1.5 mbps on speedtest.com.
  3. #13
    NBR Super Moderator
    Oct 2005
    Secret Laboratory
    It's weird since inSSIDer shows your network as the one using two bonded channels which means 40MHz channel width.
    Since there are other devices using 2.4GHz band apart from 56 Wi-Fi networks you can see that are not shown on the graph you should test each channel and see which one gives you best speeds.
    Also make sure that no power-saving options are enabled for your Wi-Fi card (device manager/advanced tab and Windows power options).
    To be brutally honest the only real solution for you is to move to 5GHz band which means changing the router and Wi-Fi card.
  4. #14
    Nov 2011
    I checked power settings and it is set to Maximum Performance..
    I'm sure your right, I knew when I ordered this computer to go with a better wifi card but unfortunately I didn't.. Now it will cost me more money. I'm going to give up on this router for now, im gonna go and pick up one of my old linksys routers tonight and try that out. Also, where can I get a wifi card that is compatible with this PC without going to alienware? because they are expensive, which one would you recommend?
  5. #15
    NBR Super Moderator
    Oct 2005
    Secret Laboratory
    Intel 6200 or 6205 would be fine (not 6230 though).
    Two stream and dual band, quite reasonably priced these days.
    Card itself won't cost you that much- it's the router that will make your wallet $80-100 thinner.
  6. #16
    Nov 2011
    Alright cool (not the router part) but atleast I know what I gotta do now. Man all of this just to wreck people in battlefield oh well, im sure after im all done it will be better then ever.
    Thanks tijo/downloads appreciate the help.
  7. #17
    Sacred Blame
    May 2010
    Terca Lumireis
    A setup like mine shouldn't cost too much these days. I got an Intel 6200 ($20) and a Linksys E3000 ($60 if you find a deal). I used to be alone on 5GHz, but one of my neighbors upgraded his router so now we're two sharing the whole band. It is still pretty much deserted though. There are other great dual band routers available though like the Netgear WNDR3700.
    Current: Precision M6700¦3720qm¦2x240GB SSD + 256GB mSATA¦32GB DDR3 1600MHz¦Firepro M6000
    Previous: Asus G73Jh-A2¦920xm¦160GB G3 + 7K750¦Chastity vBios¦ICD7 + 0.5mm pads¦Intel 6300
    Old: Asus N50Vn-B1B P8600 2.4GHz¦4GB DDR2 800MHz¦500GB 7200RPM¦9650M GT 1GB
  8. #18
    Nov 2011
    Well just to update, I went and got my old Linksys Wireless G router and everything seems fine now, my speeds are fast 12+ mbps on speedtests downloads are quick, I can actually stay in game now without getting disconnected from servers... i guess this card and the router just didnt get along.. go figure. i'll probably update to 5GHz connection soon anyway so thanks for the pointers
