Results 1 to 9 of 9
Thread: Having a problem with my wifi
7th July 2006, 07:39 PM #1Notebook Consultant
- Join Date
- Apr 2006
- Posts
- 111
- Rep Power
- 18
I have the e1705 and my wifi does not work always. Its more luck to catch it working. It works perfectly fine. Just sometimes when I turn on my computer it is as though my notebook doesnt even have a wifi card, it forgets it has one. Then I have to reboot it a few times to make it remember. Pretty weird since I realy on wireless on campus since its free.
Any advice. I tried pressing FN and
f2 but nope. Thanks if you can come up with a solution.
7th July 2006, 07:43 PM #2Notebook Consultant
- Join Date
- Apr 2006
- Posts
- 111
- Rep Power
- 18
Re: Having a problem with my wifi
I now reboted my notebook and Im using wifi now. Its a real hastle. If you can find a solution to my problem please help me out thanks
7th July 2006, 07:47 PM #3
do you have the dell card or the intel? Have you reinstalled your drivers
Dell Inspiron e1705
Intel Core 2 Duo Processor T5600 1.83GHz
WUXGA Display w/TrueLife 1920x1200
2GB DDR2 SDRAM 533MHz
120GB 5400RPM SATA Hard Drive
8x DVD+/-RW
256MB ATI Mobility Radeon X1400
Intel PRO/Wireless 3945 802.11a/g
Windows XP MCE
Bluetooth
6 cell Battery
7th July 2006, 07:50 PM #4
Did you reformat and reinstall Windows? If so, did your wireless work prior to that? Did you install the correct drivers?
7th July 2006, 09:02 PM #5Notebook Consultant
- Join Date
- Apr 2006
- Posts
- 192
- Rep Power
- 18
try pressing Fn+F2 a few times when you have issues?
7th July 2006, 09:08 PM #6
My family owns a Dell XPS 140 or something like that, discontinued of course. Sometimes it takes a full minute for the wireless to connect even when I am sitting in my own home right next to the router. Having a lot of background and start up processes delays the startup of the wireless card. Does the card find and capture the signal only to drop it again? or does it never find it in the first place? Do you see the little wireless icon pop up on your system tray?
7th July 2006, 09:11 PM #7Notebook Enthusiast
- Join Date
- Apr 2006
- Posts
- 19
- Rep Power
- 18
I would say to try and use the newer wireless drivers that might help or try disabling and re-enabling in the bios, but would do the following in this order:
- Download newest drivers. (may have to check intel's site as well)
- Uninstal old drivers.
- Reboot.
- Install New drivers.
- Reboot.
Hope it works.
--Dijital
Let me know if it works.________________________________
Dell Inspiron E1705
2.0 GHz Duo Core T2500
2GB DDR2 667 Corsair Value Select
17.0" WUXGA (1920x1200!!)
GeForce 7900 GS 256MB
Intel Wireless 3945 ABG
Dell Bluetooth 350
100GB Fujitsu 5400 rpm hdd
8x DVD+RW/-/DL Burner
9th July 2006, 10:04 AM #8Notebook Consultant
- Join Date
- Apr 2006
- Posts
- 111
- Rep Power
- 18
I did reinstal windows. I did instal the wifi drivers,it seems to be that the computer doesnt recognize the wireless card at times. I will try to reinstal the drivers form the site. As for which wifi card I have it is the one that came with the computer from dell, I believe its intell but im not sure Il check it out later, right now Im using wifi so for now its okey thanks. later.
12th July 2006, 10:56 PM #9
Make sure you're installing the right wireless drivers..intel drivers for the intel card or dell drivers for the dell card.
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Yesterday, 02:21 PM in Gaming (Software and Graphics Cards)
