Quantcast belkin network usb hub - no router
Results 1 to 4 of 4
  1. #1
    Sep 2010
    Default belkin network usb hub - no router
    so i bought the belkin network usb hub thinking i could connect it straight to my laptop's network card, but when it arrived i found out i need to connect the hub to a router via ethernet, which would then connect to my laptop.
    Firstly i don't have a router, secondly this is not what i want. I just want it to be sitting 2m away from my laptop, connected to it wirelessly and pugged into the mains. Is there any quick-fix for this, could i just buy some cheap wireless adapter, plug that into the hub then connect that to my laptop or something? Or am i going to have to return the product, and if so is there anything else which would fit what i'm after?
    Thanks.
    Clevo W150HRM
    / 15.6" Full-HD Matte LED NTSC 95% / Intel i7-2630QM / GeForce GT 555M 2GB / 8GB DDR3 (2x 4GB) / 128GB Crucial M4 / Windows 7 Professional x64 / Blu-Ray ROM / DVD±R/W / Intel 6300 Ultimate-N / What now? /
  2. #2
    NBR Super Moderator
    Jul 2006
    NBR Moderator HQ
    Default Re: belkin network usb hub - no router
    That Belkin device is a piece of trash depending on your needs. I tested a newer unit about a year after the initial review and got the same results so I highly doubt they resolved the major concerns I had with the device.
    For wireless USB applications with that hub you need a router. Another potentially useful option is a wireless usb hub but I've never had the pleasure of reviewing one.
    Desktop   13.3" Macbook Air
    W7 Ultimate, Core i7 2600k, Crucial M4 128GB SSD
    8GB RAM, GTX 680, 3x Dell U2412M Surround
       Snow Leopard, 1.86GHz, 2GB RAM
       128GB SSD, iPod Touch, 32GB iPad
  3. #3
    Forum Moderator
    May 2007
    Canada
    What devices do you want to connect to the network USB hub?
  4. #4
    Sep 2010
    I'm not looking to connect anything which needs fast speed or high power, just things like game controllers, printers, keyboards etc. all the little things.
    Clevo W150HRM
