Results 1 to 7 of 7
26th December 2011, 04:07 PM #1Notebook Enthusiast
- Join Date
- Nov 2008
- Posts
- 42
- Rep Power
- 12
Intel Centrino 6300 vs Generic wireless
I am shopping around for a laptop, and I am trying to ascertain whether the $35 would be worth the upgrade to the intel 6300. My concern is not so much the throughput of the card, but more the range. At my university, I will be staying at a university residence that has opted to cover the rooms using MANY routers spammed all over the show. This results in excessive interference and sometimes one cannot even establish a connection. Would the 6300M assist in this situation?
27th December 2011, 12:04 AM #2
Re: Intel Centrino 6300 vs Generic wireless
What do you mean? Does each room have its own router, are there many separate networks, or are there a couple of networks but many routers for them to cover a broad area?
With my living situation I have many networks visible (5-60+ depending on the time and/or how many people are living here). No, the 6300 can't help you there. I really haven't noticed any improved anything versus the old generic wireless N card that was in there. Waste of money unless you have a fancy router to connect to and a need for high wireless data transfer rates.
I know not with what weapons World War III will be fought,
but World War IV will be fought with sticks and stones. -A.E. 1947
27th December 2011, 09:18 AM #3
I disagree. I upgraded my wifi card from a 1x1 Atheros AR5B195 (AR9285 1x1 + BT) to a 2x2 Intel 6230. While it is only a 2x2, the signal strength has increased a lot as compared to when I had the Atheros card. a 3x3 card will provide larger range and throughput as compared to a generic 1x1, so if you feel the price is okay then go for it. No harm done if you get it.
Join the NBR Folding@Home Team - 213698
Apple MacBook Pro 9,1: i7-3615QM | 8GB DDR3 1600MHz | 512MB GDDR5 NVidia GeForce GT650m w/ Intel HD Graphics 4000 | 256GB OCZ Vertex 4 + 750GB WD Scorpio Black
Asus N43SL: i7-2630QM | 8GB DDR3 1333MHz | 2GB DDR3 NVidia GeForce GT540m w/ Intel HD Graphics 3000 | 500GB WD Scorpio Black
Acer Aspire TimelineX 3820TG: i5-520m | 4GB DDR3 1066MHz | 1GB DDR3 ATi Mobility Radeon HD 5650 | 640GB WD Scorpio Blue
27th December 2011, 09:32 AM #4Notebook Enthusiast
- Join Date
- Nov 2008
- Posts
- 42
- Rep Power
- 12
I will probably end up buying this if the generic card is not adequate after testing:
Intel Centrino Ultimate-N 6300 wireless card A/B/G/N | eBay
That should fit into a Sager NP8180, right?
27th December 2011, 09:38 AM #5
Yes it will fit fine although 6300 makes more sense than 6200 only if you install the third antenna.
If you don't plan on doing so go straight for 6200.
27th December 2011, 09:39 AM #6
I have the Intel 6300 in my current notebook; previously I had always gone with the generic wireless cards. The 6300 has far better signal strength through walls and over distance. The $35 is well worth it, IMO.
It's equally important to make sure your router is positioned correctly - not under a desk and so on.NotebookReview Writer & Reviewer
hp EliteBook 8740w 17" DreamColor2 1920x1200, Windows 7 Pro, Core i5-560M, ATI FirePro M7820, 8GB RAM, 120GB Intel 320 SSD, Intel 6300 WLAN
Notebook Warranty Guide | Computer Optimization Guide | SSD Upgrade Guide: How and Why
27th December 2011, 09:40 AM #7Notebook Enthusiast
- Join Date
- Nov 2008
- Posts
- 42
- Rep Power
- 12
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 02:52 AM in Gaming (Software and Graphics Cards)
