Results 11 to 20 of 174
9th June 2012, 11:26 AM #11Notebook Consultant
- Join Date
- Feb 2007
- Location
- Kansas
- Posts
- 121
- Rep Power
- 16
Re: Wireless router buyer’s guide 2012
"NOTE: Please avoid v3- it's completely different and nothing that's been written here about v2 applies to v3"
My nephew wanted to buy his parents a wireless router for streaming so I told him about the Netgear WDNR3700 you recommended here and Best buy has it NETGEAR - RangeMax Dual-Band Wireless-N Router with 4-Port Gigabit Ethernet Switch - WNDR3700-100NAS
How do you know though if it's v2 or v3?
9th June 2012, 11:47 AM #12
Assuming info on BestBuy's website is correct (which I'm not entirely sure of) it's v2 as they are referring to a "Powerful 680MHz processor" which is Atheros AR7161 680MHz used in V1 and V2. Version 3 is equipped with a Broadcom BCM4718A1 which is either 480 or 533MHz.
But BestBuy might have just copied the description...
9th June 2012, 12:10 PM #13Notebook Consultant
- Join Date
- Feb 2007
- Location
- Kansas
- Posts
- 121
- Rep Power
- 16
Thanks I guess he'll just have to buy it and hope it's v2 then!
11th June 2012, 12:11 AM #14
Work:
Dell Latitude E6520 \ 17" 1920x1080 \ Intel Core i7-2760Qm \ NVS 4200M \ 8GB RAM \ 300GB HDD
Home:
Lenovo IdeaPad Y470p \ 14" 1366x768 \ Intel Core i7-2670Qm \ Radeon HD 7690m \ 8GB RAM \ 750GB HDD
Portable:
Sony VPCZ1190X \ 13.1" 1600x900 \ Prem Carbon \ Intel Core i5-540m \ GeForce GT 330M \ 6GB RAM \ 192GB SSD
11th June 2012, 06:53 AM #15
Sorry I must have missed your post the first time.
Are you sure that all devices are set to dynamic IPs?
It may be a config issue on the Linksys although it shouldn't drop connections in the first place...
Your current setup won't cause any issued for a WNDR3700 in terms of load.
Something that couldn't be done it those days on Linksys was assigning IP addresses by MAC addresses of the cards so you keep dynamic IPs but router always assigns the same IP to the same device- that way you can configure everything in advance.
11th June 2012, 03:33 PM #16
Thanks for the info. I'm quite certain all of the devices are set to dynamic IPs, though I'm not physically at home to check. Yes...assigning the same IP to a device each time is definitely what I would love to be able to do. I've noticed with the Linksys that sometimes a device has a .101 address and then other times has a .105, and other times .102, etc. The addresses get shuffled around the various devices. Sometimes rebooting a computer seems to collapse the whole network, but it happens randomly as well. So the WNDR3700 will allow me to preset IPs based on MAC address? That would be splendid to be able to assign everything in advance.
Work:
Home:
Portable:
11th June 2012, 03:38 PM #17
Yes WNDR3700 can assign IPs by MAC addresses.
11th June 2012, 04:31 PM #18
Work:
Home:
Portable:
11th June 2012, 08:59 PM #19
Crap, so the Best Buy router is the v3 of the WNDR3700. @downloads, is it a good enough router to keep? Should I keep looking for the v2? There is nothing on the box that tells you it is v2 or v3. I had to bring the thing home and open it up and look at some of the paperwork in order to tell...
Work:
Home:
Portable:
11th June 2012, 09:39 PM #20
It's probably not bad but it has nothing in common with WNDR3700- different main chip, different Wi-Fi radio resulting in different range and throughput.
It's up to you if you want to keep it or not- I probably wouldn't.
4Likes
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 02:21 PM in Gaming (Software and Graphics Cards)
