Quantcast DLink DIR-655 Very slow, unstable Wireless connection, HELP
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Jun 2007
    Default DLink DIR-655 Very slow, unstable Wireless connection, HELP
    Hey.
    DLink DIR-655 Very slow, unstable Wireless connection, HELP.
    I have full connection speed on wired connection, but when using wireless it is very unstable and download speeds very slow.
    Sometime the internet will work full speed on wireless and most of the time it lags alot and very slow.
    I have Cable internet.
    Firmware: 1.34NA
    I already did factory default, reset router, still nothing.
    How can I fix this?
  2. #2
    Notebook Virtuoso
    Mar 2006
    Default Re: DLink DIR-655 Very slow, unstable Wireless connection, HELP
    How far are you from the router?
    What type of security are you using WPA(2)....
    Apple MacBook Pro 15", dual boot
    Netgear FVS-338 8-port VPN router,
    Dlink DGS-1216T GigE switch,
    Netgear WNDR3700v2 used as AP
    3 Snap4500 NAS units
  3. #3
    Jul 2009
    Midwest
    Run a scan with InSSIDer and see if maybe you are getting a lot of channel crosstalk.
    Also, that router is under powered (which will eventually create more and more issues) so the signal will rise and fall a lot.
    Sony VGN-SZ750N - Win7 x64, 4gigs ram, Intel 40GB SSD, Intel 5300 Win7 X64 upgrade guide
    Fujitsu Stylistic ST5020D tablet - Ubuntu, 1.25gigs ram, Wacom Penabled for graphics work.
  4. #4
    Jun 2007
    I just replaced the router with an old dlink wbr 2310 and it is working perfectly fine but not as good range as the dir 655, so there is definately something wrong with the dir 655 just need to find out what.....
  5. #5
    NBR Super Moderator
    Oct 2005
    Secret Laboratory
    Make sure that you are using the same wireless channel on both D-Links and that the firmware is up to date.
    If it doesn't help- don't be surprised DIR-655 is one of those routers that should have never been crated.
  6. #6
    Sep 2007
    San Diego, CA
  7. #7
    Aug 2009
    Did you recently upgrade the firmware? The Dlink forums have a ton of people who upgraded the firmware and then everything went to heck...
    Acer 1810T - SU7300, 11.6", 320gb HD, 4 gigs RAM, 6 cell, etc...
  8. #8
    Jul 2009
    Midwest
    Quote Originally Posted by johnw91498 View Post
    I wish I could say that surprises me, that router has a very long history of that.
    If you have the money, ditch it and buy something better, that router has been a lemon since day one.
  9. #9
    Sep 2007
    San Diego, CA
    Quote Originally Posted by leslieann View Post
    The first version of the DIR-655 is one of the best commercial routers around. The second and third versions were good as well. After that, all downhill.
  10. #10
    NBR Super Moderator
    Oct 2005
    Secret Laboratory
    Quote Originally Posted by kevinla View Post
    I would disagree completely unless you want to claim that routers were/are OK but firmware is and was hopeless- that I could agree with.
SEO by vBSEO 3.6.1
