Quantcast HP Wireless Printer Problem (UDP port 427)
Results 1 to 4 of 4
  1. #1
    Apr 2008
    Default HP Wireless Printer Problem (UDP port 427)
    Hey guys... i just bought a new wireless printer and when i install it the following message shows up:
    Your computer is unable to communicate with your printer at 192.168.1.6. This may be caused by firewall software. If you are using firewall software, verify that UDP port 427 is unblocked for both inbound and outbound traffic.
    Your PC can not communicate with your printer at address 192.168.1.6. Check all cable connections. Check that the printer, PC and router are powered on and connected to the network.
    i have bit defender firewall and created a rule for this ip and for the port itself. but it still doesn't work...
    any suggestions?
  2. #2
    Titles Shmm-itles
    Aug 2007
    Austin, TX
    Default Re: HP Wireless Printer Problem (UDP port 427)
    I assume you can ping the IP address.
    It also helps to list your OS and router.
    Dell Inspiron 1420 HP tz2500 Tablet PC Lenovo X200T Dell XT2 x 2
    Too close for missiles/ Switching to guns
    Jack Daniels/ Jim Beam/ Johnnie Walker/ Jose Cuervo
  3. #3
    NBR Super Moderator
    Oct 2005
    Secret Lab
    Does it work with the firewall off?
  4. #4
    Apr 2008
    @ surfasb: OS win7, router NetComm NB9W
    @ downloads: yes it did work when the firewall is off, but only the first time after installation. i tried to deactivate the firewall another time and a message saying there's no communication showed up
SEO by vBSEO 3.6.1
