Quantcast HP NX9010 and wireless
Results 1 to 3 of 3
  1. #1
    Aug 2004
    Default HP NX9010 and wireless
    Im buying a HP NX9010 laptop and i just wanted to know what will i have to buy to set up Wifi, im completely new to all this. Thanks.
  2. #2
    Mar 2004
    Default
    You can to set up wireless internet in your house? I assume the hp laptop comes with an internal wireless card. Then all you need to buy is a wireless router.
    Fujitsu S6210: 1.6Ghz PM ~ 768MB RAM ~ 60GB 7200RPM Hard Drive
  3. #3
    Jun 2004
    Default
    What kind of internet connection do you have at home, dsl, cable, or plain old dialup. there is an article either at Tom's Hardware or Anandtech about doing your own wifi for home/SOHO.
    Fujitsu S6210, 1GB DDR333, 80GB 5400RPM, DVD+/-RW
    -=-=-=-=-=- http://www.jotographer.com -=-=-=-=-=-
