Quantcast The best simultaneous dual-band wireless n router?
Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
  1. #1
    Apr 2009
    Default The best simultaneous dual-band wireless n router?
    Tryng to find the best simultaneous dual-band wireless n router for my home network since my old belkin is starting to go.
    I've been looking around the net for a few days and i dont think i want to go with either the Linksys WRT610N or the D-Link DIR 825 after reading countless bad reviews about frequent dropouts, firmware problems, poor range etc.
    At the moment the Netgear WNDR3700 seems to be my best bet but still a couple of poor reviews out there for it (same with any product though i suppose).
    Anyone got any better ideas?
    On my network i will have 1 pc and 1 printer wired to the router and 1 pc (wireless g), 2 laptops (both wireless n with 1 being used for gaming) and an xbox360 connected wirelessly, if thats any help.
    Acer Aspire 6935G
    Intel Core 2 Duo P8400 2.26 GHz 3MB L2 Cache 1066 MHz FBS
    4GB DDR3 1066MHz
    NVIDIA GeForce 9600M GT 512MB GDDR3
    320GB 7200rpm
    Bluray Rom/DVD Super Multi
    16" 1366 x 786 WXGA
    Windows 7 Home Premium
  2. #2
    I am the walrus
    Mar 2007
    Default Re: The best simultaneous dual-band wireless n router?
    There are, as you noted, bad reviews about all of them. I think you've got it covered with what you have seen so far. I'd probably opt for the D-Link myself as its ratio of positive to negative reviews seems a bit better.
    Or, wait until the technology matures.
    A desperate man for desperate times
  3. #3
    Dec 2007
    Montreal
    Since I have a Linksys WRT 600-n , wrt 610-n , D-link 825 and a Netgear WNDR 3700 I can say the 3700 is the best of the lot .
    5 wireless , 1 wired COMPUTERS , 1 X-Box , 1 NAS , 1 Blu ray player . X-box and Blu ray plugged into D-link DAP 1522 bridge/AP
    HP 8510-p X-9000 6gb G-Skill , OCZ ram Fire -gl 5600 HD640 GB 7200 RPM XP Pro-64/Win7 Ult 64
    Asus N-10j A-2 , 2,0 GHZ O/C Atom , 640 gb 7200 rpm HD, 2gb ram 9300gs
    HP 2133 Mini 2gb ram , 640gb 7200rpm WD HD
    HP 8530 CPU T 9600 Quadro 770 8 gb Gskill ram
  4. #4
    Apr 2009
    Thanks guys, think i'll opt for the 3700. From reading reviews and such online, and jerrys recommendation, the 3700 seems to be the best of the bunch.
    I could wait for the tech to mature, but since i need a new router anyway i may aswell give it a try. If there are any problems, i can always take it back.
    Acer Aspire 6935G
    4GB DDR3 1066MHz
    320GB 7200rpm
    16" 1366 x 786 WXGA
  5. #5
    Aug 2009
    You probably don't want to hear this, but...
    I tried out the Netgear 3700. Got it based on reviews from Amazon, Newegg, and a few other sites.
    Easy set up and was up and running in 20 minutes. Fired up the PS3 to play some Modern Warefare 2 and the network was stable for about an hour. Dropped and I had to reboot. Stable again for an hour and again had to reboot. Next, the connection only lasted about 30 minutes. After that, I packed everything back up and returned it to Fry's.
    Based on the sales guy recommendation, I got the D-Link 655. Up and running in about 30 minutes. Fired up the PS3 hoping there'll be no problems. I played Modern Warefare 2 for over 5 hours with no drops.
    Acer 1810T - SU7300, 11.6", 320gb HD, 4 gigs RAM, 6 cell, etc...
  6. #6
    Nov 2008
    I've had great luck with D-Link too.
    Latitude E6500 / Intel T9800 / 4GB / Nvidia Quadro NVS 160M / LG WUXGA / Intel 5300 WLAN / 410 BT UWB / Webcam / Fingerprint Reader / Backlit keyboard / 9 cell battery / XP Pro/Win7x64 Ultimate
    Mini 9 / 32GB Runcore / 2 GB / Bluetooth / Win7 Premium / Ubuntu 9.04
    Mini 10v / 16GB SSD / 2 GB / Bluetooth / Webcam / Win7 Premium
  7. #7
    Apr 2009
    Yes but it only supports 2.4ghz. I wanted a true dual band router so i could have g running on one band and n on another at the same time. If my understanding is correct, if i have it running on mixed mode on one band my wireless n products will only run as fast as my wireless g products. Or have i got it all wrong?
    Acer Aspire 6935G
    4GB DDR3 1066MHz
    320GB 7200rpm
    16" 1366 x 786 WXGA
  8. #8
    Dec 2007
    Montreal
    PS3 is G band no ? , I have a ps3 , an xbox and blu ray running through a dap1522 bridge and have not rebooted in 3 weeks , between DL and transfers have put over 1 Tbof data through the 3700 with no hiccup .
    And Dave you got it right
  9. #9
    Aug 2009
    Dave,
    The other band is the 5ghz, but it is quite limited. When I tried to connect my PS3 to the 5ghz band, my signal was less than 5%. Unless the component is very close, you'll get a very weak signal with constant drops.
    Jerry,
    I'm not sure why the Netgear 3700 didn't like my set up. I have a very basic network, but I couldn't keep a stable connection. Also, my wife does vpn 3 days a week and the 3700 doesn't do vpn pass through very well. That was a huge deal breaker.
  10. #10
    Jun 2008
    Quote Originally Posted by The Dave View Post
    WNDR3700 is currently one of the best wireless routers to get. Another option is WRT610N version 2.0. But for this one, be sure to get the version 2.0, since it has solved problems of the version 1.0. And if it's true that this version 2.0 uses the same chip as WRT320N, then its 5GHz band - 40 MHz channel downlink throughput might outperform WNDR3700, just as WRT320N do (at least according to smallnetbuilder).
    Fujitsu LifeBook S6410
    T9500|4GB|GM965|500GB 7200RPM w/3D Sensor|WiFi 5300|13.3" LED|1.3MP|Fingerprint|BT|WWAN MC8780
    Dell Inspiron Mini 910 White
    N270|2GB|945GSE|32GB SSD|5300 w/3rd antenna|8.9" LED|1.3MP|BT
    Dell Studio 1735 Red
    T9300|4GB|PM965|2x320GB 7200RPM|WiFi 5300|17" WUXGA 1920x1200|2MP|Backlit Keyboard|Fingerprint|BT|WWAN MC8781
SEO by vBSEO 3.6.1
