Quantcast asus laptop does not auto connect to wireless network
Results 1 to 6 of 6
  1. #1
    Jan 2009
    Default asus laptop does not auto connect to wireless network
    hello all
    i have an ASUS X58L laptop (running XP Pro) with built in wireless and a BT home hub 2
    the laptop detects the wireless network but does not auto connect unless you turn off the wifi before you shut down and then turn it on after it has booted up
    there is a wireless client (cant think of the name) as well as windows
    i have tried stopping the client at bootup but still no good
    it does connect if you connect manually and the connection is good.
    a mate bought his laptop down last night ( fugitzu siemens) and that connected automaticlly
    i was wondering is it ok to remove the wireless client thats on the laptop and just keep windows to do it.
    i dont want to remove it and mess it up
    thanks
    David
  2. #2
    Jan 2009
    Default Re: asus laptop does not auto connect to wireless network
    there should be a setting in either the windows wireless manager or your network card's software (can't recall which and I'm at work) that says "let windows manage this connection"... it'll basically let windows take over using its generic (but usually effective) wireless configurations, avoiding any problems your driver may have.
    Best of luck
  3. #3
    Jan 2009
    yes windows is set as the manager of the connection but it still only auto connects if its booted up with the wlan off.
    not a prob though as you can connect manually
    thanks
    David
  4. #4
    Lazy as the Day is Long
    Jul 2006
    The SSR of NYC
    What service pack for XP Pro are you running?
  5. #5
    Jan 2009
    service pack 3
    thanks
    David
  6. #6
    Jul 2006
    The SSR of NYC
    You should be fine removing the third-party client and just letting the built-in .Windows functionality handle making the connection.
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
