Quantcast Installing a third internal antenna for wifi card
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Knock 'em out!
    Apr 2008
    LA
    Default Installing a third internal antenna for wifi card
    I will be installing a third antenna in my laptop shortly to go with my new Intel 5300 wifi card. The problem is, I haven't really been able to find any sort of guide to help with the installation process. I suppose I can just route it around the body of the laptop and tape it down but that won't exactly give me the optimal reception/range. Does anyone have any good guides or perhaps some tips you can share with me before I do this?
  2. #2
    1 hr late but moving fast
    Apr 2006
    PCB, Florida
    Default Re: Installing a third internal antenna for wifi card
    Go to oxfordtec.com and buy an antenna. Thread it through any opening on the bottom of the laptop - works like a champ.
    If you have a problem, do everyone a huge favor: post the exact error message. Don't abbreviate or paraphrase.
    New to forums? You really should view this video!
    XPS 15 L502x: Core i7-2670QM, 8GB RAM, Intel HD4000 + nVidia GeForce GT 540M , Dual Band Wireless-AC 7260, 180GB Intel SSD, Windows 8 x64 Pro with Media Center
  3. #3
    Knock 'em out!
    Apr 2008
    LA
    I already bought a Tyco WLAN antenna. What do you mean by thread it through any opening on the bottom of the laptop? Should I wrap it around in a circle around the body of the laptop underneath the cover or should I stick it somewhere specific?
  4. #4
    Moderately Boss
    Aug 2007
    Sydney
    It depends on your notebook. Most notebooks thread the antenna wire to the LCD assembly for best reception.
    Try wrapping the antenna into the wifi compartment and see what sort of reception you get first. You might not even need to extend it.
  5. #5
    Knock 'em out!
    Apr 2008
    LA
    Awesome, thanks.
    And how do I know which antenna is good? Which would you choose out of these?
    OxfordTEC
    or
    Tyco
  6. #6
    Apr 2006
    PCB, Florida
    You already have the Tyco, so just use one of those two antennas in that package. You can just push the antenna through the hole next to the wifi card (where the other antennas go) until the entire length is inside the case.
  7. #7
    Knock 'em out!
    Apr 2008
    LA
    Well I'm actually upgrading 2 laptops this weekend so I'd need 2 antennas anyway. Should I get another Tyco or the one from OxfordTEC?
  8. #8
    Apr 2006
    PCB, Florida
    Didn't you get two antennas from that eBay order?
  9. #9
    Knock 'em out!
    Apr 2008
    LA
    Yeah good point. Still I'm curious, would the OxfordTEC be better?
  10. #10
    Apr 2006
    PCB, Florida
    I don't think so. All antennas are pretty much the same.
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
