Results 1 to 10 of 22
2nd December 2008, 11:21 AM #1Notebook Enthusiast
- Join Date
- Jul 2007
- Posts
- 37
- Rep Power
- 15
[Wireless G vs. Wireless N] Will I notice a Difference?
I just order the HP HDX16t with the Wireless N card. Currently I only have a Wireless G router at my home. Should I upgrade? Is the speed noticeable?
I will be gaming, downloading lots, web browsing.
Also is Wireless N is draft? What is draft anyways? Should I wait till its actually released?
Thanks
2nd December 2008, 11:35 AM #2
Re: [Wireless G vs. Wireless N] Will I notice a Difference?
if you have a very fast internet connection
2nd December 2008, 11:48 AM #3
The difference isn't in the browsing, its in the network speed. Wireless n allows for much faster file transfers over a network than wireless g, worth it if you work on 2 or more ,achines.
2nd December 2008, 12:18 PM #4
You won't notice the difference unless you're transferring very large files around between computers that are on your own private subnet - with respect to the internet, the limiting factor will be your ISP's speed, not your internal router's speed.
2nd December 2008, 04:31 PM #5Notebook Enthusiast
- Join Date
- Jul 2007
- Posts
- 37
- Rep Power
- 15
When I look to see when Wireless N will be available it says 2010..
whats that mean? The full version or what? What is draft n?
Should I purchase a N router now? I have comcast, fast speeds.
2nd December 2008, 05:55 PM #6
even with comcast the fastest service they provide is 16mb down and thats the cap, i have it as well and dont even see past 10mb.
wireless g i believe caps at 54mb/s and runs on a 2.4ghz frequency vs a n that does 108 that runs at a 5ghz frequency.
wireless n is good if you plan to stream media around the house, if you're just browsing the net and playing games a G is sufficient enough and you'll never use it to the full extent.Azusagawa: RV02|QX9650|Striker II Extreme|8GB OCZ SLI PC3-14400|VelociRaptor RAID 0|EVGA GTX 470x3 SLi|X-Fi Ti Fatal1ty|TurboCool 1200w|Watercooled|G9/19|
2nd December 2008, 07:57 PM #7
Draft N is an incomplete version of the Wireless N technology which hasn't complied with the standards as of yet...
#flickr - flipfire
[Desktop] Silverstone LC20B | Q8200 2.8ghz | GTX680OCE | 8GB RAM | 128GB M4 SSD | 12TB HDD | Intel 6300N |
[Notebook] HP DV2500 Verve SE | T7500 | 8400GS | 4GB DDR2 RAM | WD 250GB HDD | Intel 4965AGN |
[Worktop] NZXT Apollo | i7-3770 | GTX 460SE | 12GB DDR3 | 120GB Intel 330 SSD | M-Audio Delta 66 |
2nd December 2008, 11:24 PM #8Notebook Virtuoso
- Join Date
- Aug 2006
- Posts
- 2,359
- Rep Power
- 26
Wireless N is greater than Wireless G by all standards. Every darn Wireless G router I had always gave at least one system a problem to connect wirelessly, especially when that system was taken out of the house and connected to a different network then brought back home. Not with wireless N, everything just connects and works. No more headaches.
Asus N61JQ-A1
16" HD WXGA LED 16:9, i7-720QM, 4GB DDR3, 500GB 7200RPM, 4X Blu-Ray Burner, Mobility Radeon HD5730; 2-3 hours battery life
3rd December 2008, 09:15 AM #9Notebook Enthusiast
- Join Date
- Jul 2007
- Posts
- 37
- Rep Power
- 15
So buy a new router? Any ones you recommend? Under $100
5th December 2008, 04:04 AM #10Notebook Consultant
- Join Date
- Dec 2008
- Location
- New Zealand
- Posts
- 196
- Rep Power
- 11
11n usually uses MIMO or basically more than one antenna to receive and send at once.
This can give much better range than single antenna 54g.
Some cards come with 3 antenna's, most older draftn come with 2.
11n routers and WLAN cards will also have the latest security features. WPA2 etc
If you have a NAS device attached to your LAN you can access it much faster then a 54g connection.
Intenet will make no difference if you have 54g or 11n the limit as already said is you connection speed.
ADSL2+ maxes at 24Mbps and that is if you live in the exchange.
Go 11n, 54g is so yesterday.
2.4Ghz (G) = better range but often very populated in build up areas.
Only 3 non overlapped channels so lots of chance of interference from other 11n routers and phones, some remotes and video senders.
5Ghz (A) = less range (shorter wave lenght) but hardly anyone uses this so not many devices to interfere with connection.
12 non over lapped channels, more room to change channels if one or more are busy.
I have a Buffalo dual band 11n router that can simultaneously transmit/receive in 11na and 11ng, the ultimate solution.
I'm currently using a Gigabyte GN-WS30N Ralink based WLAN card, it's only 11ng but it's awesome Client Utility in Vista makes up for lack of 11na.Dell i9400
T7400 2.16Ghz CPU
4GB 667Mhz RAM
nVidia go7900GS
Gigabyte GN-WS30N WLAN
Vista x64 Ultimate
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Yesterday, 10:11 PM in Gaming (Software and Graphics Cards)
